Aftermarket Crank Pulley/Stock alternator Pulley Belt....Questions
Old Jun 21, 2007 | 10:02 AM
_Spugen_'s Avatar
Default Aftermarket Crank Pulley/Stock alternator Pulley Belt....Questions
So I just purchased this car and it turns out it has a aftermarket crank pulley and the stock alternator one. The belt had been makin noise and it finally gave out while driving and I couldnt find the belt. So What kinda belt do you guys think would fit?? The motor is a d16z6....I tried the stock one from autozone but it fits really loose still.
Old Jun 21, 2007 | 10:19 AM
Mr.EM1_EK's Avatar
Default Re: Aftermarket Crank Pulley/Stock alternator Pulley Belt....Questions (_Spugen_)
see if you can contact whoever you bought the car from and ask them what brand pulley. maybe you can get the belt from whoever made that pulley.
Old Jun 21, 2007 | 10:22 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: Aftermarket Crank Pulley/Stock alternator Pulley Belt....Questions (Mr.EM1_EK)
Put a stock pulley back on it.
Mr.EM1_EK's Avatar
Default Re: Aftermarket Crank Pulley/Stock alternator Pulley Belt....Questions (ReDemoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReDemoN &raquo;</TD></TR><TR><TD CLASS="quote">Put a stock pulley back on it.
that would be a good idea also.
Old Jun 21, 2007 | 11:31 AM
Padawan's Avatar
Darth ModerVader
Use a piece of string to measure the belt length you need. Then take the old one with you to the auto parts store and buy a replacement of the proper length that matches that style.
Old Jun 21, 2007 | 11:32 AM
_Spugen_'s Avatar
Thats the thing I dont have the old belt...Its couldnt find it in the street. The crank pulley has two grooves that are rather close together...
Old Jun 21, 2007 | 05:20 PM
_Spugen_'s Avatar
Heres another thing...The crank pulley has two grooves while the stock one has three. I just put a belt that fits the alternator pulley perfectly but not so much on the crank. The only other thing I could try is a two groove belt on the crank pulley...but it wont sit right on the alternator. Any other opinions?
Old Jun 21, 2007 | 08:19 PM
_Spugen_'s Avatar
Bump...Help!
Old Jun 22, 2007 | 05:08 PM
slowcivic2k's Avatar
Default Re: (_Spugen_)
Put the damn factory pulley back on it, before your oil pump decides to go on vacation, its simply not worth it, and if the belt snapped and fell off, odds are the grooving and the alignment of the pulley is off which will only snap another belt.
JDM H22
Honda S2000
Nov 20, 2008 07:18 AM
slowpro
Oct 3, 2008 07:23 AM
mickiemagik
Mar 29, 2007 04:11 PM
94SiHatch
Mar 24, 2004 10:45 PM
TeamTooQuick
Sep 11, 2003 09:52 PM
