What happened to z10? i need nipples!!
hey guys, i woke up this morning and decided to go along with making my own breather set up with moroso catch can and 2 crank case hoses linked to it and wanted to get the z 10 plugs cuz they are wider diameter than the honda prelude ones, unfortunatly the website doesnt seam to link to them... is the company dead?
Does anyone know how big z10 nipple diameter were or where i can get similar crankcase nipple fittings in 3/4 outer diameter, if they exist? The guy at jangs told me that his moroso catch can with 2 side nipples number 85466 is fitted with 3/4 nipples. So basically, i'm assuming I would only need to find 3/4 hoses and my setup with be cheaper by 100$ than the endyn setup sold for 200$. I do not wish to return the blow by gases back into the motor so i wont need a 3rd hose under the catch can or a T setup... thanks for the help guys, i searched my *** off before posting but all the links from z10 are offline now since they date back in 2004... here is the adress to the catch can if anyone is interested in this setup option :
http://www.jegs.com/webapp/wcs...28_-1
Modified by Mugen Type R at 9:10 PM 6/21/2007
For the plug I think I just just used a freeze plug from the autozone. Worked just fine, tapped in with a rubber mallet.
