Valentine 1 hardwire question (RE: wires)
Old Jun 21, 2007 | 05:41 AM
p nut's Avatar
Default Valentine 1 hardwire question (RE: wires)
I need to hardwire my V1, but I do not know which wires go where. Below is the picture of the wires. There are four. Which wires do I connect to the power source, and which ones are grounded?
Thanks.
Old Jun 21, 2007 | 06:16 AM
fcm's Avatar
fcm
Old Fart
Default Re: Valentine 1 hardwire question (P Nut)
, that looks like the V1 is not a 12V system, or not all of it is, what did you do with the lighter plug in, it may have a transformer in it. 94
Old Jun 21, 2007 | 06:41 AM
B18C_EJ8's Avatar
If it's anything like the Passport, there's power & ground and 2 signal wires that the unit uses for it's external display & mute button.
Old Jun 21, 2007 | 07:25 AM
p nut's Avatar
Default Re: Valentine 1 hardwire question (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> , that looks like the V1 is not a 12V system, or not all of it is, what did you do with the lighter plug in, it may have a transformer in it. 94</TD></TR></TABLE>
I still have the cig lighter plug, but the wire drapes right across the radio. The wire above is from an actual hardwire kit, but the end was torn off in an accident I was involved in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">If it's anything like the Passport, there's power & ground and 2 signal wires that the unit uses for it's external display & mute button.</TD></TR></TABLE>
That's what I was thinking, too. So, obviously, red=power, black=ground, and 2 accessory wires?
Anyone confirm this? Also, if I do want to use the concealed display and mute, where do I connect the green and yellow wires to? Do I just tap them all into the power source?
Old Jun 22, 2007 | 09:52 PM
SoCal EJ1's Avatar
Mine's up by my rear view mirror, with the wire tucked up in the headliner, down the A pillar, under the dash and through a small hole in my center console, plugged into the cig. adapter. Looks hardwired with no effort. However, if I remember correctly, the kit comes with a little clip/pin thing so you can hardwire it up in 2 seconds. The only reason I haven't done it is because I have no idea what to wire it to so I'm not messing with it.
Old Jun 22, 2007 | 11:50 PM
bpr0422's Avatar
The V1 comes with a hardwiring kit.. (Item 20305)
instead of using the crappy connector they provide.. just get a female quick disconnect, and crimp it to the kit's power wire...
then put that to your accessory 12+ or ignition 12+
and then wire the ground accordingly...
you really didn't have to go through all that trouble of stripping and cutting a telephone wire...
jmai86
Audio / Security / Video
10
Mar 10, 2008 02:06 PM
marvinmark21
Jan 14, 2008 12:06 PM
Reelizmpro
Oct 15, 2004 04:03 PM
enhancedCL9
Feb 10, 2004 10:51 PM
rs
Sep 22, 2003 07:50 PM
