Hondata
I want to do hondata in my car. Just want to know do I go with hondata s200 or hondata s300. I am leaning more towards the s200 any suggestions on which one is easier to work with. I have a 92 hatch with ls/vtec and I/E... Any suggestion or help will be greatly appreciated...
Guest
Posts: n/a
i installed the hondata s100 just because it was cheap and very reliable and needed something good to tune with. hasnt disappointed me yet. also what do you plan on doing with your motor. i believe the s200 and s300 are for more aggresive n/a and turbo builds. if decide that route then those to would recommend, just the basic set-up s100 would be the way to go. hope that helps and im sure youll get more info from everyone here.
go with the s300....from experience....the s300 is alot easier to tuned and dink around with... can preprogram fuel maps.... save them as well....with s200 each time your want to change data one would have to burn new chip...BOTTOM LINE GO WITH THE S300....BETTER ON YOU IN THE LONG RUN.
