4 X 100 to 4 X 114.3 Wheel Adapter
Old Jun 20, 2007 | 06:01 PM
jdmcivic1's Avatar
Default 4 X 100 to 4 X 114.3 Wheel Adapter
If you want to put 4 x 114.3 rims on 4 x 100 car. Will getting adapters be better and cheaper than the 4 x 114.3 conversion?
https://www.adaptitusa.com/ind...ID=83
Good Idea or Bad Idea?
Old Jun 20, 2007 | 07:27 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 4 X 100 to 4 X 114.3 Wheel Adapter (jdmcivic1)
I wouldn't, for all kinds of reasons. For one thing, the adapter is going to push the wheels out at least an inch from the car, which means you may need to roll your fenders, etc. Also, there are lots and lots of 4x100 wheels available on the market to fit, both new and used, so it's a lot cheaper and easier to stick with 4x100 wheels that fit your car, instead of getting the wrong wheel and then bending over backwards to figure out a way to use it.
SiR2EG6
May 9, 2011 05:55 PM
importdreamer
Suspension & Brakes
Feb 16, 2005 03:46 PM
SioneSi
Nov 2, 2003 05:25 PM
DB2-R81
May 22, 2003 10:00 PM
BlahBlah95Teg
Jul 28, 2002 01:25 PM
