y8 dizzy fit on z6 head?
No. Get an OBD2 distributer.
A 92-95 non-Z6 or non-Z1 would fit, but you'd have to re-wire the plugs. I'm not sure if they're even the same amount of teeth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">No. Get an OBD2 distributer.
A 92-95 non-Z6 or non-Z1 would fit, but you'd have to re-wire the plugs. I'm not sure if they're even the same amount of teeth.</TD></TR></TABLE>
y8 dizzy IS obd2. No wiring changes involved, just some hacking up of the flange like I said.
you have to shave the flanges? as in the 2 things sticking out that go into the head? i know you also have to file the holebigger if you want all 3 bolts to match up.. so i would have to do what now? little more detail
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">Thier basically direct swaps, but re-wiring is required for OBD swaps.</TD></TR></TABLE>
z6 distributors have a different bolt pattern
SPOON_BeIgHtEeNsEe
May 1, 2008 12:46 PM
