92 INTEGRA CODE 16 RUNS LIKE %e^#@# HELP ME (searched for ever)
throsing a code 16 in my 92 teg. obd 1 i have noticed that the fuel injectors seem to work. has any one ever swaped the 92-95 civic sohc injectors in one? and have they worked?
when i have been checking info they say that they are the same 240cc as the civic. and when checking specs between the 2 they both are tested the same way. what i mean is as far as resistance. they both call for 10-13 ohms. the only thing that is diff is the plugs where you plug them in. and they are not that much different.
I did when I thought my original ones may be bad, this is on my daily and I ended up leaving them in they have been in for about 3 years
i swaped mine at lunch and they worked. car still runs like pooo dont know what to do next,
head was replaced with newer year one and compression is 135 psi accros the board.
any help
any help
slowdx
16
Jan 23, 2004 08:20 AM
