code 15 with no spark after DPFI to MPFI swap
Old Jun 5, 2002 | 07:08 PM
red civic standard's Avatar
Default code 15 with no spark after DPFI to MPFI swap
engine cranks over. getting air and fuel, just no spark. code 15 (Ignition output signal). What does this mean? Could it have something to do with the crank angle sensor that I had to wire in? Will the distributor not spark if the ECU does not see the crank angle sensor?
Old Jun 5, 2002 | 07:27 PM
fixhondas's Avatar
Default Re: code 15 with no spark after DPFI to MPFI swap (red civic standard)
Check the two white wires on the dist plug- the thick one goes to location #6. Looks like this
---12---
--3456--
---78---
[Modified by fixhondas, 11:28 PM 6/5/2002]
Old Jun 6, 2002 | 06:20 AM
KevronsEG's Avatar
Default Re: code 15 with no spark after DPFI to MPFI swap (fixhondas)
ttt
Old Jun 6, 2002 | 09:35 AM
Default Re: code 15 with no spark after DPFI to MPFI swap (CIV616)
there are two white wires that go into the distributor plug. would this problem occur if I had reversed the wires when splicing on the Si distributor plug?
Old Jun 6, 2002 | 11:10 AM
zCivic's Avatar
The car will start if you have the blue/green and blue/yellow wires xed up. It will throw code 9. Double check you 2 white wires in the diz they could be xed up and if thats the case it will not start.
Old Jun 6, 2002 | 12:52 PM
fixhondas's Avatar
Read my previous post.
Old Oct 18, 2002 | 01:07 PM
joshwhe's Avatar
iam throwing a code 16 and it idles high ???? i thought 16 was the out put singal ?????
Old Oct 18, 2002 | 01:13 PM
Stupid Ass's Avatar
Default Re: code 15 with no spark after DPFI to MPFI swap (joshwhe)
Code 16 is your Injectors bro... did you wire them up correctly to the resistor box and ECU...
Old Dec 14, 2002 | 05:45 AM
Crxfanatic15's Avatar
Default Re: code 15 with no spark after DPFI to MPFI swap (-= UnKoiled =-)
I had a code 15 throwing when i did my z6 swap and it was my wiring harness that was bad i went through 3 before i got one to work
Old Dec 14, 2002 | 06:00 AM
Hondasaurs's Avatar
What engine did you put in place of the DX? You should have used a modified DX harness on what ever engine you put into this car.
Justin95-si
Apr 25, 2012 10:56 PM
apekd
Feb 21, 2009 05:09 PM
miller.91.HB
May 25, 2004 09:50 PM
atomikpunx
10
Feb 3, 2004 10:57 AM
dpine
Sep 22, 2003 07:37 AM
