k20?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brjhnson »</TD></TR><TR><TD CLASS="quote">Freddy is correct, look on youtube for k20 hatch. Its gold?yellow and they try to run 40 but it blows
no they wanted to run 30 but it spiked to 41
</TD></TR></TABLE>no they wanted to run 30 but it spiked to 41
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 »</TD></TR><TR><TD CLASS="quote">opps, 41psi, my bad
http://www.youtube.com/watch?v=-p9Jec-yhB8
do 30psi, u will be fine.</TD></TR></TABLE>
That motor was blown during that test run, bud.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brjhnson »</TD></TR><TR><TD CLASS="quote">The car was running 20 or so psi and they tried to run 42 and it spiked at 41.somthing and blew</TD></TR></TABLE>
The story went, they were running at 20lbs, then they wanted to adjust for 38lbs, and it spiked at 41lbs and the engine was toast.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2Fiend »</TD></TR><TR><TD CLASS="quote">so which k20 can run 29psi stock?</TD></TR></TABLE>
d17 can hold ~27psi stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fventura03 »</TD></TR><TR><TD CLASS="quote">i think they used a regular k20a2</TD></TR></TABLE>
Yes, it was a K20A2.
You guys do realize these quoted psi numbers mean nothing correct?
You can be saying that you can run 29psi on a stock motor and some idiot is going to strap on a GT47 and blow his motor.
The larger the turbo, the more CFM's it flows versus a smaller turbo at the same psi, which makes a vague boost pressure guide to engine durability a horrible idea.
Judging volumetric air displacement = better idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraFanatic »</TD></TR><TR><TD CLASS="quote">You guys do realize these quoted psi numbers mean nothing correct?
You have to remember that regardless of the airflow in the charge tubing, the intake manifold should flow at relatively the same rate, given the constant in the equation (aka. the PSI).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2Fiend »</TD></TR><TR><TD CLASS="quote">so when u say stock d17 can hold 27psi does that mean daily driver and all?</TD></TR></TABLE>
Who said a stock D17 could hold 27psi? That's not the slightest bit true.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2Fiend »</TD></TR><TR><TD CLASS="quote">so how much can it really hold stock then?
the most common psi for em2 i see is 14psi. can you go higher on a stock engine?</TD></TR></TABLE>
With a stock intake manifold, the highest you'll get is 9psi. With a modified Y8 manifold, maybe you'll see 12.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
With a stock intake manifold, the highest you'll get is 9psi. With a modified Y8 manifold, maybe you'll see 12.</TD></TR></TABLE>
my buddy's boosting ~10psi on a t25 stock mani doing fine... (i think)
life sux die
Honda Motorcycles
Sep 21, 2006 08:37 AM
