Mass smoke and code 21 after head gasket change..
Old Jun 19, 2007 | 04:49 PM
jdmpremonition's Avatar
Default Mass smoke and code 21 after head gasket change..
I have searched through like 20 pages trying to get some info but haven't had any luck.. so i thought id make a post. I just replaced my Head gasket on my 94 gsr motor in a 93 hatch and didn't replace the head studs due to lack of funds. when we started it, it ran fine, when i drove the car it ran fine all up until i cracked vtec then all of a sudden my car starts spitting mass white smoke and eventually dies. i get it home and check the codes and now im throwin a code 21 along with the code 10 i was throwing previously and it starts up and runs fine until it starts smoking then it loses power and dies. i pulled the spark plugs and looked at them and it didn't seem like they had anything on them at all like coolant or anything. im about ready to just take this motor out and put in a stock ls if i cant fix the problem. could it just be the head studs? if so then why the code 21? any input would help alot thanks guys..
Old Jun 19, 2007 | 05:20 PM
Supra_y0's Avatar
leakdown test?
Old Jun 19, 2007 | 05:29 PM
DecentCivicZ6's Avatar
B A N N E D
21*- Accord Civic CRV CRX Del Sol Odyssey Prelude
94-98 ** 92-95 n/a n/a 93-95 n/a 93-95
VTEC Solenoid Valve
defective circuit or unplugged / defective solenoid valve
10- Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98
IAT Sensor (Intake Air Temperature)
defective circuit or unplugged / defective sensor
Old Jun 25, 2007 | 01:20 PM
i already know what the codes are for and we did a compression test and all 4 cylinders were the same im thinking i might have a warped head...
wallendiaz
Nov 27, 2012 01:31 PM
new_climber
Jan 21, 2009 06:14 PM
all-mtr-teg
Nov 5, 2007 04:55 PM
vtec93accord
Jan 3, 2004 05:11 PM
