clutch pedal is on the ground
Old Jun 19, 2007 | 04:33 PM
relited's Avatar
Default clutch pedal is on the ground
search is down for me atm, and i bled the clutch no bubbles in the line, and my pedal still sits on the floor, im really tired and pissed off, i got a CEL too but no code, im using a chipped p28 so im not sure if that has anything to do with it but i had a CEL using the p14 ecu as well, umm i put a paper clip in the blue connector jumping both pins, no code, what should i do honda tech? my car runs but i can't go anywhere if i dont have a clutch
Old Jun 19, 2007 | 04:53 PM
Giant_Bean's Avatar
Default Re: clutch pedal is on the ground (relited)
clutch master cyl. took a dump on you
Old Jun 19, 2007 | 05:35 PM
SikB's Avatar
Since I assumed you checked your fluid. I would check where your slave cylinder hits the clutch fork in front of the tranny. Make sure that the slave is bolted in correctly and that the pin that connects the slave and the fork is connected. Also make sure that the their is no play in any of that stuff.
Old Jun 19, 2007 | 05:41 PM
relited's Avatar
yea its hitting the fork but when the clutch is depressed it does absolutely nothing and the pedal hits the floor
Modified by relited at 1:56 PM 6/20/2007
Old Jun 19, 2007 | 09:23 PM
prelude1897's Avatar
Default Re: (relited)
either your master or your slave cylinder has gone out, either way, you should change them both out so that you don't have to redo the whole process if the other goes out on you. It's best to replace both at the same time
Greenery18
Jul 8, 2005 04:22 PM
SPOOLINmatt
Mar 14, 2005 01:04 PM
FLCivic
Jun 30, 2004 03:48 PM
g00se
Mar 8, 2004 06:11 PM
geminis2k
Nov 20, 2003 11:33 AM
