strange noise coming from driver rear tirewell?
theres a strange noise coming from what seems to be the driver-sider rear tire. The thing is, is that the noise is NOT coming from the tire since the noise doesn't go faster as i go. it kinda sounds like 'Tst tst tst'
but you get the idea
and i hear the noise only in motion and above 40mph.
It's a constant noise and is driving me crazy!
Maybe it's a badger?
Haha, do you have aftermarket suspension? It could be your bushings are squeaking, even on stock suspension. Or check your sway bar/tie bar. Loose lug nuts maybe? Messed up brake? Torn boot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InLtegSra94 »</TD></TR><TR><TD CLASS="quote">Maybe it's a badger?
Haha, do you have aftermarket suspension? It could be your bushings are squeaking, even on stock suspension. Or check your sway bar/tie bar. Loose lug nuts maybe? Messed up brake? Torn boot?</TD></TR></TABLE>
which bushings can it be?, i have aftermarket suspension and i have no swaybar.
do the rears have boots?...i never even noticed
i will check the brakes....thanks alot for the advice
Yambor
Suspension & Brakes
Apr 30, 2006 08:01 PM
