obd0-obd1 swap help no spark!
Old Jun 19, 2007 | 03:39 PM
white90rexsi's Avatar
Default obd0-obd1 swap help no spark!
Here is the setup, 1990 crx si, locash racing obd-1 conversion harness and sub harness, locash racing distributor adapter, rywire obd1 distributor. I try and start the car and I have no spark, and my tach does not move. My fuel pump is comeing on and the ecu is ready.
I called locash and he thought maybe 4 wires on his dizzy jumper harness may be crossed, I switched them but it did not do anything. Does anyone have a diagram for this adapter so I can make sure it is correct? This harness plugs into the obd0 cicrle plug on my crx harness and goes to the obd1 plug on the dizzy.
Any ideas?
-Chris
Old Jun 19, 2007 | 03:55 PM
Default Re: obd0-obd1 swap help no spark! (white90rexsi)
I am looking at the diagram "hondaprtshero" posted and it looks like my #7 wire is mismatched, if I am looking at it right.
Old Jun 19, 2007 | 05:50 PM
abnaasefmb's Avatar
sorry i don't have a diagram but it's probably your wires on the dizzy or a fried coil. sorry couldn't be more help. i'll look around
Old Jun 19, 2007 | 06:00 PM
abnaasefmb's Avatar
Default Re: obd0-obd1 swap help no spark! (abnaasefmb)
http://hondaswap.com/hybrid-ed...3435/
Old Jun 19, 2007 | 09:35 PM
cr-x-91's Avatar
check ur grounds. make sure u put the one on thermostat.
Old Jun 20, 2007 | 02:12 AM
Default Re: (cr-x-91)
I have all my grounds on, t-stat, tranny, valve cover. Ths distributor is brand new. I know its not the coil because my tach is not moving. I think this dizzy jumper harness from locash is wired wrong. I am going to repin it and try this afternoon.
Thanks,
-Chris
Old Jun 21, 2007 | 01:32 PM
Default Re: (white90rexsi)
Ok, 5 of the wires on the locash jumper where in the wrong spot. I got the car to spark now, but it will not start! I will post back later after I check out some other things.
Tippyman
10
Sep 24, 2016 09:10 AM
becauseracecar8
Feb 24, 2016 07:10 PM
CivCruise
Sep 10, 2009 07:49 AM
iamjdm
Jul 11, 2006 09:38 AM
JohnnyB70
Dec 2, 2004 05:56 AM
