92-95 Honda Civic parts 4 sale.
Old Jun 19, 2007 | 03:26 PM
E.Honda's Avatar
Default 92-95 Honda Civic parts 4 sale.
I have bunches of parts for 92-95 Honda civic coupes, hatches and I am also parting out a 4 door.
Parting out this 91 Accord SE.
Front seats are already sold.
https://honda-tech.com/zero...age=2
So you are short on cash....I will trade for most anything of equal or greater value.<U></U>
<U>I have tons more parts than pictured.</U>
I can make these brake pad covers for just about any car.
Link to more pics of different covers.
https://honda-tech.com/zerothread?id=2345229
BLACK OR GREY GLOVE BOX DOORS.
CLUTCH AND BRAKE PEDAL ASSEMBLY
The factory rubbers are under the covers and in great shape.
D SERIES P/S PUMP
MOTOR MOUNT
Will work with b16 and d16 into an eg chassis
Great Condition.
WIPER SWITCH 01-05 CIVIC
HEADLIGHT SWITCH 01-05 CIVIC
01-05 INGITION SWITCH WITH KEY AND KEYLESS REMOTE.
01-05 CRUISE BUTTONS
MOROSO DIST CAP
Fits:Accord 98-02 Civic 95-00 CRV 97-01 Del Sol 95-97 Integra 94-01
$22.50 shipped
MAROON CONSOLE
CONSOLE BRACE
UNDER DASH TRIM
DOME LIGHT
DOME LIGHT
FITV
fast idle thermo valve
D SERIES POWER STEERING PUMP BRACKET
D SERIES REAR T BRACKET
REAR HATCH TRIM PARTS BLACK
AIR BOX WITH FILTER
FRONT LEFT SUSPENSION FORK
MAIN RELAY
WIPER ARM NUTS
Minty New!!
BLACK END COVERS FOR DASH
BLACK DOOR SILL COVERS
Missing a tab or two but still very useable and clean.
SRS CLOCK PLUG MISSING
$12.00 SHIPPED
UNPAINTED LICENSE PLATE SURROUND
Lights and wiring intact. Lenses sold seperate.
BLACK FUSE DOOR
GRAY DOOR LOCK SWITCH
EBRAKE CONSOLE
Has a small clean crack at the back of the handle.
Would not show up in pic.....22.50 shipped. Comes with matching bolt cover.
RIGHT SIDE POWER MIRROR
$25.00 shipped
NEEDS PAINTED
LEFT AND RIGHT SIDE POWER WINDOW/LOCK WIRING HARNESSES.
Black dash vents.
AC CONDENSOR FAN
REAR SWAYBAR FROM A 93 EX COUPE
[B]LEFT SIDE TWEETER AND POD WITH MOUNTING BRACKET[B]
VSS
STEERING COLUMN UNIVERSAL
Removed from a 97 civic.
PAIR IF 2000 Si MIRRORS
Someone primered them. Will seperate.
SUNROOF RELAYS and BRACKET
[B]HONDA O.E.M. KEYLESS REMOTE[B]
Has good battery
TAIL LIGHT HARNESS$10.00 SHIPPED
[B]FAN RELAYS WITH BRACKET[B]
15.00 SHIPPED
[B]92-95 TILT STEERING COLUMN[B]
NON TILT COLUMN
IGNITION SWITCH WIRING
TRUNK & GAS DOOR RELEASE HANDLES
DRIVERS AIRBAG
ANOTHER DRIVERS AIRBAG
STEERING WHEEL
Has some wear at the top.
ANOTHER STEERING WHEEL
No wear showing.
CLOCK SPRING
D SERIES A/C BRACKET
[B]HEADLIGHT / WIPER SWITCH MOUNT[B]
WIPER SWITCH
HEADLIGHT - BLINKER SWITCH
LEFT SIDE FENDER TRIM tabs are not broken. $10.00 shipped
[B]D SERIES IACV[B]
[B]POWER BRAKE ONE WAY VALVE[B]
[B]THE LEFT SIDE HOSE IS PERFECT[B]
[B]$10.00[B] shipped
92-95 POWER DOOR LOCKS.
SET OF 95 EX CALIPERS with GOOD PADS.
MASTER CYLINDER COVER
FUEL RAIL
HEAT SHEILD D16Z6
BATTERY TRAY. No metal cancer.
LICENSE PLATE LIGHT LENSES.
WINDSHEILD MOLDINGS.
INNER TAIL LIGHT COVERS. No scratches. The dirty one will clean perfect.
FOUR DOOR LEFT SIDE HEADLIGHT. No chips or scratches on lense.
FOUR DOOR RIGHT SIDE HEADLIGHT. Broken mounting tabs. Perfect lense
CLOCKS $25.00 SHIPPED.
POWER WINDOW AND LOCK SWITCHES.
Window switches are gray. I have one black and one gray door lock switch.
BLACK DASH FROM A 95 COUPE with or without airbag. It is very dusty.
A/C LINES
D SERIES SHIFT LINKAGE 5 SPEED.
LEFT REAR MAROON 4 DOOR REAR INNER HANDLE WITH SWITCH.
O.E.M RADIATOR AND FAN
(Will seperate)
FAN BLOWER MOTOR.
VTEC
MAP SENSOR
STOCK B SERIES CAM GEARS
REAL LEATHER SHIFT BOOT FROM A RARE BLUE COW.
SET OF INJECTORS
RIGHT INSIDE DOOR HANDLE WITH GOOD LOCK TAB
D SERIES UPPER TIMING BELT COVER
GREY 3RD BRAKE LIGHT out of a 94 EX COUPE.
The black one has sold. I have a grey one still.
Needs a little dusting off. No damage.
Complete A/C system for 92-93 d series.
mirror switch
sunroof switch
cruise control actuator motor.
Radiator with cap.
Wiper Motor.
2 door coupe right side power window regulator and motor.
2 door, door glass....Both sides.
MUCH MUCH MORE!!
Will update with many more pics later.
Have a good day!!!
E.Honda
Modified by E.Honda at 5:51 PM 11/16/2008
Modified by E.Honda at 5:57 PM 11/16/2008
Old Sep 7, 2007 | 11:45 AM
sol_white's Avatar
Default Re: 92-95 Honda Civic parts 4 sale. (E.Honda)
how much for the A/C system
Old Sep 7, 2007 | 05:40 PM
E.Honda's Avatar
Default Re: 92-95 Honda Civic parts 4 sale. (sol_white)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol_white &raquo;</TD></TR><TR><TD CLASS="quote">how much for the A/C system</TD></TR></TABLE>
pmed
Old Sep 7, 2007 | 08:49 PM
E.Honda's Avatar
srdtyj
Old Sep 8, 2007 | 02:39 PM
E.Honda's Avatar
jytf
Old Sep 8, 2007 | 05:51 PM
E.Honda's Avatar
,ug
Old Sep 9, 2007 | 05:21 PM
E.Honda's Avatar
lhb
Old Sep 9, 2007 | 07:01 PM
Keeper1343's Avatar
how for the speaker covers, the big piece that goes across the center and gauges and center vent on top of the dash shipped to 19057 Serious buyer plz respond
Old Sep 9, 2007 | 07:09 PM
Keeper1343's Avatar
how for the speaker covers and center vent on top of the dash shipped to 19057 Serious buyer plz respond
Old Sep 10, 2007 | 08:40 AM
E.Honda's Avatar
Default Re: 92-95 Honda Civic parts 4 sale. (Keeper1343)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keeper1343 &raquo;</TD></TR><TR><TD CLASS="quote">how for the speaker covers and center vent on top of the dash shipped to 19057 Serious buyer plz respond</TD></TR></TABLE>
pmed
Old Sep 10, 2007 | 09:45 AM
wmertz187's Avatar
is that a b or d series header? also do you have the factory camber for the read, specifically to fit on an EG
Old Sep 10, 2007 | 01:55 PM
E.Honda's Avatar
Default Re: 92-95 Honda Civic parts 4 sale. (wmertz187)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wmertz187 &raquo;</TD></TR><TR><TD CLASS="quote">is that a b or d series header? also do you have the factory camber for the read, specifically to fit on an EG</TD></TR></TABLE>
D series header.
Old Sep 10, 2007 | 09:38 PM
E.Honda's Avatar
RETH
Old Sep 11, 2007 | 10:29 AM
E.Honda's Avatar
k
Old Sep 11, 2007 | 02:56 PM
E.Honda's Avatar
sdryuj
Old Sep 12, 2007 | 07:19 PM
E.Honda's Avatar
dyh
Old Sep 13, 2007 | 06:28 AM
E.Honda's Avatar
up
Old Sep 13, 2007 | 05:40 PM
E.Honda's Avatar
rth
Old Sep 13, 2007 | 07:40 PM
E.Honda's Avatar
erth
Old Sep 13, 2007 | 09:33 PM
E.Honda's Avatar
Have a great weekend bump.
Old Sep 14, 2007 | 11:40 AM
E.Honda's Avatar
Hello bumpo
Old Sep 14, 2007 | 08:23 PM
E.Honda's Avatar
up
Old Sep 15, 2007 | 04:58 AM
ghostcivic's Avatar
POWER MIRROR INSIDE COVERS and DASH BEZEL how much shipped to 45177 thanks
Old Sep 15, 2007 | 10:29 AM
E.Honda's Avatar
Default Re: 92-95 Honda Civic parts 4 sale. (ghostcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostcivic &raquo;</TD></TR><TR><TD CLASS="quote">POWER MIRROR INSIDE COVERS and DASH BEZEL how much shipped to 45177 thanks
Dash bezel is already sold.
PMED about covers.
Old Sep 15, 2007 | 05:48 PM
Mike
Interested in the upper timing belt cover.
Shipped to 32792.
