Owners of 99 Accord V6?
Old Jun 5, 2002 | 06:11 PM
TakaIntegra's Avatar
Default Owners of 99 Accord V6?
My girlfriends 99 Accord's dash light (behind the odometer) went out. Is it easy to fix? Is there a bulb behind the dash for this or do I need to get a new LED odometer.
Old Jun 5, 2002 | 06:31 PM
4doorH22's Avatar
Default Re: Owners of 99 Accord V6? (TakaIntegra)
Awww man, a '99? Warranty expired?
Old Jun 5, 2002 | 06:39 PM
-RedneckDave-'s Avatar
Working
Default Re: Owners of 99 Accord V6? (4doorH22)
if the guage cluster is the same as mine and i have a 2001 then it should be pretty easy. There are two screws on the black plastic piece around the guages but be careful when you pull out the piece because there are two metal clips that are near the bottom and they have a tendency to break but it is ok if you break one cause the piece still stays in firm and then there are 5( i think) star drive screws to take out before you can take out the cluster and then there are three connectors to undo and after that there are just twist in things for a multiple of bulbs on the back and you just have to find the right one. hope this helps you some
Old Jun 6, 2002 | 10:09 PM
Default Re: Owners of 99 Accord V6? (01accordv6)
O1accordv6 thank you sounds the same as the integras
crc13
Mar 12, 2008 05:26 AM
ondenoantra
Apr 28, 2004 06:55 PM
ej0513
Nov 2, 2003 02:38 PM
