Can i use type r b18c5 oil pump in b18b
Old Jun 19, 2007 | 02:06 PM
turbahatch's Avatar
Default Can i use type r b18c5 oil pump in b18b
Just like the topic states iv searched and cant find anything i know if i use the water pump i will need to get the gsr belt but what if i use the ls water pump and the gsr/type r oil pump???? Will i still need to use the gsr/type r belt or can i run the ls belt?
Any help much appreciated!!!
Old Jun 19, 2007 | 05:22 PM
chad's Avatar
Moderator
Default Re: Can i use type r b18c5 oil pump in b18b (turbahatch)
yes
Old Jun 19, 2007 | 06:39 PM
doood's Avatar
been there done that
Default Re: Can i use type r b18c5 oil pump in b18b (chad)
all 96+ b series oil pumps are the same thing
Old Jun 19, 2007 | 07:27 PM
pvt_awol's Avatar
Default Re: Can i use type r b18c5 oil pump in b18b (doood)
......I thought just the VTEC ones were the same? It would make no sense that a '98 LS blocks original oil and water pump would need to be swapped out for GSR or ITR ones to facilitate 8000+ rpms in an LS/VTEC build.
I think you are partly right, but only the VTEC ones are the same.
Old Jun 19, 2007 | 07:29 PM
doood's Avatar
Default Re: Can i use type r b18c5 oil pump in b18b (pvt_awol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pvt_awol &raquo;</TD></TR><TR><TD CLASS="quote">^
I think you are partly right, but only the VTEC ones are the same. </TD></TR></TABLE>
the water pumps are different from vtec to non yes, but look at the part numbers for the oil pumps and they're the same starting in 96.
even in bambam's lsvtec thread he states they're the same
Old Jun 19, 2007 | 10:17 PM
turbahatch's Avatar
So is that a yes because i have a 2000 block and that would be newer than 96
Old Jun 20, 2007 | 07:20 AM
chad's Avatar
Moderator
you can run a pre 96 oil pump....they are all the same internally....the pre 96 don't have a spot for the crank angle sensor that is mounted to the oil pump and will need the right timing belt cover for 96 newer oil pumps
stevenDAtegra
Dec 15, 2008 07:53 AM
hydroflip
Aug 6, 2007 02:07 PM
civicswap
Mar 5, 2005 04:04 PM
bens_redeg
Jul 10, 2004 07:11 AM
shawn_crx
Jan 25, 2004 12:34 AM
