b18b hp gain
Old Jun 19, 2007 | 01:35 PM
m7869ike's Avatar
Default b18b hp gain
what are some simple things i can do to my b18 to gain some hp... and if so what would i gain..
like cams, headers.... is it even worth it?
Old Jun 19, 2007 | 01:41 PM
Agent_EM1's Avatar
Default Re: b18b hp gain (m7869ike)
Nitrous Turbo That's my $.02 ... It worked for a family member with a 94 LS. However he put over a 100 shot of Nitrous and he blew 2 motors but he had some good times w/ that. Upgrades w/ the nitrous were an ebay aluminum radiator, Skunk2 exhaust, and Injen intake.
Old Jun 19, 2007 | 01:47 PM
m7869ike's Avatar
haha nice... im just wondering if cams and headers will help alot.. i can't think of anything else that won't force me to take apart my engine...
Old Jun 19, 2007 | 01:48 PM
ke98248's Avatar
Default Re: b18b hp gain (Agent_EM1)
Turbo it for the best HP gains for the money spent.
Old Jun 19, 2007 | 01:53 PM
m7869ike's Avatar
im not looking to spend a grand.. maybe 400 500 bucks.. and i don;t need 300 hp.. just a little more then i have now
Old Jun 19, 2007 | 01:59 PM
EM1_00Si's Avatar
Default Re: (m7869ike)
Well it wont increase your HP, but you could always go with a shorter tranny.
Old Jun 19, 2007 | 02:02 PM
m7869ike's Avatar
ok, so what are the hp gains with cams and headers, and can i do a basic tune on a b18 to get more power out of it..
Old Jun 19, 2007 | 02:36 PM
gd99em1's Avatar
intake, header, and exhaust would be your best bets.
but unfortunately you'll hardly be able to notice a difference with those mods for the money you spend.
my opinion is either save your money and spend it on a turbo kit, or just save the money for a rainy day and be happy with what you've got.
Old Jun 19, 2007 | 03:06 PM
JMelt4's Avatar
A turbo would be the best long-term solution.
Old Jun 19, 2007 | 03:39 PM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m7869ike &raquo;</TD></TR><TR><TD CLASS="quote">ok, so what are the hp gains with cams and headers, and can i do a basic tune on a b18 to get more power out of it.. </TD></TR></TABLE>
Cams, a header, a tuning device, and paying someone to tune is going to cost you quite a bit over $400-$500.
Old Jun 19, 2007 | 03:42 PM
ke98248's Avatar
Default Re: (Slopoke)
You can spend money on an intake and exhaust, but it won't net you the results you desire for the $$ you want to spend. Try Nitrous Oxide, buy a used kit if you want a bit more HP out of your b18
Old Jun 19, 2007 | 05:12 PM
vtecftw's Avatar
are you broke and cheap? get a good nitrous setup and with a proper safety measures it will make your car much faster. using a tps sensor switch and other things to be sure you dont detonate or lean out
Old Jun 19, 2007 | 05:18 PM
Supra_y0's Avatar
boost
Old Jun 19, 2007 | 05:24 PM
Boost_V's Avatar
Default Re: b18b hp gain (vtecftw)
i personally am not a fan of nitrous. IT seems so many motors have been blown up by it. In any case, 3-500 dollars is not much, you'd only be able to get a decent dc sports header out of that...hardly worth the money. I say save your money for now towards a turbo build. I know you don't want a ton of more power, but for what you can afford now won't gain you anything. Turbo can be a lot of power or a resonable amount of power on a stock engine.
The reason i say turbo for later is because look around, look what a dc sports costs, then nice set of cams, then exhaust, then a tune. IT will add up. let us know what your thinking you're going to do.
Old Jun 21, 2007 | 08:09 AM
Boost_V's Avatar
Default Re: b18b hp gain (The Lurk Artist's Agent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lurk Artist’s Agent &raquo;</TD></TR><TR><TD CLASS="quote">ha.
want your car to be faster?
put a b16 transmission on it. throw the LS tranny away.
better and more cost effective than anything mentioned. night and day difference.</TD></TR></TABLE>
more cost effective- sure
better- i don't think so, just because his gearing would better(doesn't mean he would be as fast as i think he's shooting for. but you're right, a good tranny will be a night and day difference.
But i still think if the op saves up instead of using the few hundred dollars, he'll be MUCH happier down the road, even if he has to wait a while longer. Patience when you're on a tight budget is necassary.
Old Jun 21, 2007 | 08:18 AM
95ProjectEJ1's Avatar
If you have 4-500 dollars to spend only you are sure as hell not going to get I/H/E, or even cams and a tune. Save the money, map out your reasonable goals, and do a little research. If you are dying to do something then get a B16/GSR tranny. I have seen some go for 475-500 in good condtion. Even if you did all of those bolts ons you really wont go anywhere fast with the long LS gears.
Old Jun 21, 2007 | 09:53 AM
big-cat's Avatar
yeah b16 tranny, or a b16 head or a tune. those are your best bets.
Old Jun 21, 2007 | 10:44 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (big-cat)
Save your money. Get a good tranny and save up for a turbo.
Exhaust will be a waste of time, if you get any bolt ons get a GOOD header and an ebay intake.
Then save for something more worthwhile.
Old Jun 21, 2007 | 12:52 PM
motor_man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Save your money. Get a good tranny and save up for a turbo.
im with ek foever guy, all that stuff is not worth wile unless ur willing to spend a lot of money, so save ur money.
Old Jun 21, 2007 | 01:30 PM
97Ej6mike's Avatar
A well built and tuned Turbo LS motor can be a force to be reckoned with.
Old Jun 21, 2007 | 02:07 PM
92_VX_EG's Avatar
Default Re: (97Ej6mike)
A GSR tranny is your best bang for the buck with an LS. B16 trannies are too short for the 6,800 redline of an LS. If you had a Vtec motor and revved to 8,000+ a B16 or Type R tranny are a little better. Buy a cheap ebay intake and don't get a DC Sports 4-2-1 cause they tend to break around the welds(happened on 2 of mine). Get an ITR replica header and a test pipe/high flow cat/beat out cat. To properly do a cam swap you need the other valvetrain that goes with the cams which is well over your spending limit and won't give you that much of an increase in power with the stock bottomend. The tranny will make the most difference... you'll beat other LS' with I/H/E with a stock LS with a GSR tranny.
Old Jun 21, 2007 | 02:16 PM
big-cat's Avatar
but yes all and all your BEST BET is to save up for the t-bo, or just buy quality parts one at a time.
AcuraIntegraitr
Feb 29, 2008 07:30 AM
jaygray
Aug 24, 2004 07:44 AM
HX_Guy
Jun 26, 2001 09:45 AM
HX_Guy
Jun 24, 2001 09:15 PM
