harness and shift link problems
Old Jun 19, 2007 | 08:16 AM
drugyungrage1986's Avatar
Default harness and shift link problems
Hey wuz up guys hows it going.Well now that i finaly got the 1997 d16y7 manual motor in the 1993 del sol automatic engine bay i can worry about two things now. First one is the engine harness on the d16y7 motor. It doesnt plug up to the chassi harness on the del sol. I think i might need a little HELP there. And the second one is the shiftlinkage. I cant even go to 1st gear because the shifter hits up agents the shifter hump on the del sol chassi. I guess i might have to do a little cutting there. YEA I THINK I NEED A LITTLE HELP.
Old Jun 19, 2007 | 08:37 AM
crazyguy's Avatar
Default Re: harness and shift link problems (drugyungrage1986)
are u using del sol shift linkage? cause del sol's is shorter than eg
Old Jun 19, 2007 | 08:45 AM
Default Re: harness and shift link problems (crazyguy)
no i am using the 1997 d16y7 link
Old Jun 19, 2007 | 10:19 AM
crazyguy's Avatar
yeah u need the del sol shift linkage
Old Jun 19, 2007 | 10:21 AM
StreetRacinThug's Avatar
And you need the Del Sol wire harness man. You cant use a Civic from OBD2a to a OBD1 car
Old Jun 20, 2007 | 08:41 AM
Default Re: (StreetRacinThug)
I hope ur not talking about the 93-95 sol engine harness because it doesnt fit. Somebody told me about swapping a 96-98 integra obd2 engine harness because its a 2 peice harness. It will plug in to the del sol chassi harness and it also will plug into the d16y7 motor. Well i hope that **** is ******* true. well ill check yallll out later im a play some ******* GEARS OF WAR to relive my stress.
NewtoHonda
Feb 28, 2012 06:49 AM
riptegk20
Sep 16, 2005 06:52 PM
CaptinMcnut
Nov 12, 2004 05:01 PM
