RS Door Handles
Old Jun 5, 2002 | 05:00 PM
jond's Avatar
Default RS Door Handles
I found this post when searching, but just wanted to verify:
https://honda-tech.com/zerothread?id=176526&page=1
The last few people said they were hard to get, or expensive.
Where can you get the handles besise the dealer?
Also, the part number is: 72125-ST7-023ZA correct?
[Modified by jond, 9:01 PM 6/5/2002]
Old Jun 5, 2002 | 05:14 PM
RTW DC2R's Avatar
Default Re: RS Door Handles (jond)
This might sound like a dumb question, but are those the outside handles or the inside?
Old Jun 5, 2002 | 05:19 PM
tjtruong's Avatar
New User
Default Re: RS Door Handles (RTW DC2)
inside handles.........
they range from 6-15$ at the dealers so your best bet would be there. You might find it alittle cheaper on some internet sites, but its just not worth the time to me. I don't know of any sites though.
[Modified by tjtruong, 2:19 AM 6/6/2002]
Old Jun 5, 2002 | 08:39 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: RS Door Handles (tjtruong)
Should be about $7 per side. And yes, they may be back-ordered.
[edit] Part numbers for j00...
[/edit]
[Modified by itr009, 12:42 AM 6/6/2002]
Old Jun 6, 2002 | 06:01 AM
Cheeseman's Avatar
just buy them from the dealer....unless you can find a LS teg properly unequipped with electric locks in a junkyard....but it's not worth the energy, unless your delaer can't get them for you.
Cheese~
Old Jun 6, 2002 | 06:48 AM
RTW DC2R's Avatar
Default Re: RS Door Handles (Cheeseman)
what about outside handles? are there any that will fit that dont have key holes on the outside?
Old Jun 6, 2002 | 06:50 AM
Willard's Avatar
the rear handles off of a 4 door.
Will
Old Jun 7, 2002 | 06:50 PM
Integ Grl's Avatar
Default Re: RS Door Handles (Willard)
How hard is it to install these? Are they as simple as popping off the stock ones and putting the new ones in? What do I do with the wires? TIA
Old Jun 7, 2002 | 06:56 PM
onyx00's Avatar
Default Re: RS Door Handles (Integ Grl)
I took the old connector for the power door handles and wrapped them in soft foam and then taped them to the inside of the door so if I ever needed the connectors again, it would be easy to get them.
Then you just pop in the new ones with a screw and you are done.
Super Simple. Even itrsport.com could figure it out ;-) j/k
Old Jun 7, 2002 | 10:51 PM
PYITR821's Avatar
Default Re: RS Door Handles (onyx00)
What is the reason for removing the power locks? How do the theives use the power locks to their advantage?
Old Jun 7, 2002 | 11:37 PM
B16CRX's Avatar
Default Re: RS Door Handles (JUNtypeR)
You can try here:
http://www.haprecycling.com
They usually have what I need.
Old Jun 8, 2002 | 12:15 AM
zer0zer0 TypeR's Avatar
Default Re: RS Door Handles (B16CRX)
i'm a total n00b here but, why are we installing these on itr's again?
Old Jun 8, 2002 | 12:47 AM
NWPNOMORE's Avatar
Banned
Default Re: RS Door Handles ('00TypeR)
cause they don't have the power door lock switch. The switch aids thieves in entering your cars.
Old Jun 8, 2002 | 08:28 AM
EagleR's Avatar
Default Re: RS Door Handles (NWP4LIFE)
yup...and the outside ones w/o locks A...look better...B) Provide no lock to pick/drill....
Old Jun 8, 2002 | 11:34 AM
Rhetoric's Avatar
Default Re: RS Door Handles (EagleR)
So would it be more beneficial to just do the outside key hole fill/or switch it with the rear 4 dr. handles?
For a body shop to fill the key hole should cost much.
MaxBoost
16
Apr 8, 2005 11:09 AM
CALM_AS_A_BOMB
Nov 16, 2002 08:02 PM
thaiphob
Oct 10, 2002 10:45 AM
Splat
Mar 8, 2002 12:58 PM
