%^&*check my wiring on 4 wire o2 sensor*&^%
Old Jun 18, 2007 | 10:33 PM
vw eater's Avatar
Default %^&*check my wiring on 4 wire o2 sensor*&^%
so i have it wired like this, is this correct?iam getting ''o2 sensor a code''
i got my obd0-obd1 conversion from this web site http://www.xenocron.com/produc...rness
http://www.xenocron.com/install/OBD0-OBD1.htm
and i have this o2 sensor(walker type b)
-----02 sensor----- ----0bd0-obd1-----
black-heater--------------------- brown-o2heater control
black-heater----------------------yellow-o2 12v switch
white-sensor ground-------------perple-02 ground
blue-signal to computer ---------grey-o2 signal
Old Jun 18, 2007 | 10:36 PM
yz125rider21's Avatar
reset ecu and try it again....might be the problem mate...
Old Jun 19, 2007 | 01:35 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: %^&*check my wiring on 4 wire o2 sensor*&^% (vw eater)
you may want to reverse the black wires
Old Jun 19, 2007 | 02:04 AM
ef92b's Avatar
Default Re: %^&*check my wiring on 4 wire o2 sensor*&^% (HondaPartsHero)
heater(black wires) are non-polarized.
re-check your wires.
black-heater--------------------- brown-o2heater control= ECU Pin#A6
black-heater----------------------yellow-o2 12v switch=common to A25, B1, Main Relay, Injectors, IACV
white-sensor ground-------------perple-02 ground= ECU Pin#D22
blue-signal to computer ---------grey-o2 signal= ECU Pin#D14
phbrush
27
Dec 17, 2014 07:25 AM
jorge59la
Feb 15, 2010 08:16 PM
1992cxcivicEG
Dec 18, 2009 07:42 AM
neu-b
19
Jun 30, 2009 06:03 PM
BoM
Mar 15, 2002 10:03 AM
