A question about wheel spacers (yes I did search)
Old Jun 18, 2007 | 09:32 PM
Missouri_Civ's Avatar
Default A question about wheel spacers (yes I did search)
I have been contemplating getting some Eibach spacers for my car (92 Civic DX sedan), but I had a question about them. According to the site I checked, they offer both a 5 mm and a 15 mm option. For the 5 mm, it said it used the OE hub ring, but it didn't say anything about that for the 15 mm ones. Is there some special modification that needs to be done to the vehicle in order to use the 15 mm spacers?
Thanks in advance.
Old Jun 18, 2007 | 09:39 PM
Eran's Avatar
HT White Ops
What the everloving crap are you going to use a 15mm spacer for on a Civic?
It better be the gnarliest set of slicks I've ever seen.
Old Jun 19, 2007 | 06:17 AM
Default Re: (Eran)
Thank you for your completely worthless reply that did nothing to answer my question.
Old Jun 19, 2007 | 06:19 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Missouri_Civ)
I've never heard of anyone using a 15mm spacer, usually they just get low offset wheels.
Like Eran said, I agree, It better be one gnarly slick to even need that kind of spacer. Drag wheels come in a low offset anyways.
Old Jun 19, 2007 | 06:35 AM
Padawan's Avatar
Darth ModerVader
Default Re: A question about wheel spacers (Missouri_Civ)
Both should be hub-centric. The only modification you'll want to do is replace the stock lugs with extended ones (which I believe are included with the Eibach spacers).
Old Jun 19, 2007 | 06:38 AM
Default Re: A question about wheel spacers (Padawan)
Thank you Padawan.
Old Jun 19, 2007 | 09:34 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Both should be hub-centric. The only modification you'll want to do is replace the stock lugs with extended ones (which I believe are included with the Eibach spacers). </TD></TR></TABLE>
I figured this was implied, considering all the Eibach kits came with new studs ....
Old Jun 19, 2007 | 09:50 AM
BlackoutVTi's Avatar
Default Re: A question about wheel spacers (Eran)
So, just out of curiosity, are you using the 15mm spacers? And, if you are, what will you be needing the 15mm of extra space for? I think we're all getting a little curious about that.
Old Jun 19, 2007 | 10:13 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
I figured this was implied, considering all the Eibach kits came with new studs .... </TD></TR></TABLE>
Whether or not it was implied, I was attempting to answer his question as thoroughly as possible, especially since his original post did not mention lugs and he inquired about any necessary modifications.
Old Jun 19, 2007 | 10:33 AM
suspendedHatch's Avatar
Default Re: (Eran)
Typical Honda Tech answer. You know the answer but you side-step the question and ridicule the OP instead.
What ******* business is it of yours what he's doing? Why do you always assume it's the worst possible reason?
Old Jun 19, 2007 | 10:34 AM
Jon V's Avatar
Default Re: A question about wheel spacers (BlackoutVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackoutVTi &raquo;</TD></TR><TR><TD CLASS="quote">So, just out of curiosity, are you using the 15mm spacers? And, if you are, what will you be needing the 15mm of extra space for? I think we're all getting a little curious about that.</TD></TR></TABLE>
I'm looking for a set of 15mm spacers for my EK... Gotta get something to clear my new brakes... I think I'll be using the H&R spacers with the non integrated studs...
a 5mm and 10mm spacers as it sits...
Old Jun 19, 2007 | 10:40 AM
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Typical Honda Tech answer. You know the answer but you side-step the question and ridicule the OP instead.
What ******* business is it of yours what he's doing? Why do you always assume it's the worst possible reason?</TD></TR></TABLE>
I sure hope that's not directed towards me. I just want to know if he's got wider wheels, a brake kit with large calipers, hell even a wide bodykit. I'm not going to ridicule the guy, I'm just interested.
Modified by BlackoutVTi at 12:32 PM 6/19/2007
Old Jun 19, 2007 | 11:26 AM
igo4bmx's Avatar
Default Re: A question about wheel spacers (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">
a 5mm and 10mm spacers as it sits...</TD></TR></TABLE>
what car is that kit from?
looks good.
Old Jun 19, 2007 | 12:59 PM
Jon V's Avatar
Default Re: A question about wheel spacers (igo4bmx)
TL "Sport" model or Type S...
won't fit under anything smaller than 16" wheels
HighBoostinTeg
Jun 21, 2011 03:57 PM
BoostR41
Acura TL, RL & ZDX
Jan 24, 2011 07:05 AM
I3ooS710
Feb 2, 2006 06:17 AM
gabstar
Jul 3, 2005 11:48 AM
