EGR vacuum disconnected at valve- a/f
How much will disconnecting the vacuum line at the valve alter a/f ratios?
I've disconnected it until the slide hammer I ordered comes in. I'm getting the obvious "Insufficient lift" cel. I'm just wondering if the a/f will get too lean in doing so.
Does the amount of fuel injected get altered when the ecu sees a lack of lift from the valve?
ProLineDesigns
Dec 10, 2007 03:54 PM
