89 honda accord lx
Old Jun 18, 2007 | 05:34 PM
89accordlxdude's Avatar
Default 89 honda accord lx
i have an accord lx which is the carburated model. it sometimes has a problem starting up right away. ill turn the key it will fire up and die. other times it will take a second and ill pump the gas a few times to help it and its starts right up, then i have to hold it at around 2k rpms for just a few seconds. i dont know what this could be.
also when i begin to drive the car, and while driving at a steady speed, i can feel the car stutter like it has a miss' or something. gas millage seems like it could be a bit better. if some one can help me out with my problem that would be great. thanks if you can email me at Musicis69@aol.com because i will check there more frequent then here.
Old Jun 24, 2007 | 04:50 PM
Wobb's Avatar
Default Re: 89 honda accord lx (89accordlxdude)
it your injeters
Old Jun 24, 2007 | 04:59 PM
361 accord's Avatar
Default Re: 89 honda accord lx (Wobb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wobb &raquo;</TD></TR><TR><TD CLASS="quote">it your injeters
carbureters dont haaaave injectors
id what to tell you, ive really only tinkered with weedwacker carbs but ill bump the thread lol
Old Jun 24, 2007 | 05:22 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
I don't know if we have anyone on this forum anymore that knows that much about carburetors, other than on lawnmowers and go-karts.
It could be the carburetor choke mechanism or possibly the choke heater. The miss could be due to the sparkplugs or even the the sparkplug wires.
Best I can tell you, is do the regular tune-up. Change the air filter, sparkplugs, distributor cap and rotor, motor oil, spray some carburetor cleaner in and on the carburetor, pcv valve, etc.. On many carburated cars, you have to step on the gas first to start it, if it sits awhile.
Here is a link to a Honda with a carburetor:
http://autorepair.about.com/li...e.htm
Old Jun 24, 2007 | 08:41 PM
JDM_DC4_Fanatic's Avatar
Default Re: (tech8)
Check for a clogged fuel filter. Theres usuially a small filter located in the base of the carb. If its restriceted, it will cause hesitation, hard starting and lean running.
Old Jun 25, 2007 | 03:36 PM
Jstall7543's Avatar
if it has a carb, pump it! Thats pretty much the way they are! The choke should take over from there!
Old Jun 25, 2007 | 04:24 PM
Default Re: 89 honda accord lx (Jstall7543)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jstall7543 &raquo;</TD></TR><TR><TD CLASS="quote">if it has a carb, pump it! Thats pretty much the way they are! The choke should take over from there!</TD></TR></TABLE>
The choke is there so you dont have to pump it to start it cold.
carpdiem
Aug 18, 2014 04:10 PM
95hondaAccord
Feb 13, 2012 05:48 PM
pj.trudy
Oct 25, 2008 08:40 AM
muth123
Apr 28, 2006 06:27 AM
Vera
Mar 26, 2004 10:49 PM
