ZC Clutch? Which car
thats one bad question. first off you need to figure out what year that engine and tranny are, if I were you I would count the spline on the input shaft and go from there. You also might want to measure the flywheel and clutch disk surface, see if its any of the following. 212mm or 200mm, if its 212mm, 90=crx clutch 1.6l or Si as its called. If the its 200mm 89CRX si. on thie input shaft there will be either 21 or 20 teeth if the 21 you will need an 88 clutch. if its 20 its equivalent to a 90+crx si clutch, I would opt for thta for the larger surface area and get a matching flywheel for it. HTH
phatrick2332
Mar 31, 2004 06:11 AM
Ronin Panda
15
May 11, 2003 05:05 PM
