Dc rear lower tie bar install help
Old Jun 18, 2007 | 02:55 PM
Prudz_lude's Avatar
Default Dc rear lower tie bar install help
anybody have any tips, info, or write ups on how to do this? if there is no write up i will make one when i install it. i will be doing this on friday or saturday but would like a heads up for any parts i will need to replace. Will i need to replace anything?
Old Jun 18, 2007 | 03:11 PM
MidKnightBB6's Avatar
Default Re: Dc rear lower tie bar install help (Prudz_lude)
the instructions come with the tie bar. it is pretty self-explanatory.i got mine done in lik 15-20 minutes. however i would suggests longer screws (i forget the exact name) because i had a friend with an civic that eventually stripped his threads with gradual wear and one eventually gave out on the freeway. but other than that it's a very easy install
Old Jun 18, 2007 | 03:21 PM
Prudz_lude's Avatar
Default Re: Dc rear lower tie bar install help (MidKnightBB6)
ok sweet. it did have instructions but i bought it off someone from here. No hardware came with it. What do i need?
Old Jun 18, 2007 | 09:16 PM
Hawkze_2.3's Avatar
Just take out the LCA bolts and replace them with the bar in place. Coudn't be any easier...
And just FYI, it doesn't really do anything as the subframe already has gussets and such that are stronger than the bar...
Old Jun 19, 2007 | 05:54 AM
Finest's Avatar
Default Re: Dc rear lower tie bar install help (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">And just FYI, it doesn't really do anything as the subframe already has gussets and such that are stronger than the bar...
But it sure is purdy!
obuhmyuh
Nov 21, 2007 08:46 PM
DC2Integ01
Suspension & Brakes
Mar 12, 2007 04:45 PM
IntegraPrez
Oct 19, 2004 08:22 PM
dLo GSR-stolen-now-WRX
Jun 19, 2002 11:55 AM
