FS: Honda Civic/CRX parts
Old Jun 18, 2007 | 01:29 PM
FOMULA91's Avatar
Default FS: Honda Civic/CRX parts
Need to clean my garage so here’s the list of parts. All parts are for SOHC Civic/CRX D-Series.
ZC transmission
I recently did a clutch job and I was thinking to swap it out with a newer Si transmission, which I bought last summer but I found out (Found out the hard way after I swap everything) that it was a ZC transmission because the inner shaft was much larger and I did a research to figure it out. Will I have no use for it and I swap my old Si instead so I’m selling this one.
Asking $120 please serious buyer only.
IACV sensor for D15B7----------- $5 (already cleaned and dry so it should be fine)
88-91 Civic/CRX fan---------------$5 (one of the mount underneath is broken and the wire needs to be solder do to direct connection)
JDM D15B intake manifold------$40 (Same as the D16Z6 manifold and it’s included with fuel injector and fuel rail but not shown in the picture. But missing all the sensor/broken. Except the IACV)
88-91 CRX front bumper (little crack on driver side turn signal area)-----------------------$10
Passenger side door for a Honda CRX 90-91 model (with door mounted seatbelt). The model also came in 88 Si. Not included with side mirror or the door panel.
Asking $50.
Stock corner light. Only the passenger side---------------$5
For pics check link below
http://sandiego.craigslist.org/pts/354327456.html
http://sandiego.craigslist.org/pts/354322818.html
Located in San Diego. PICK Up only Please
Old Jun 18, 2007 | 02:12 PM
FOMULA91's Avatar
Default Re: FS: Honda Civic/CRX parts (FOMULA91)
bump!!!
Old Jun 18, 2007 | 10:32 PM
FOMULA91's Avatar
Night!!!
Old Jun 19, 2007 | 12:31 PM
FOMULA91's Avatar
Old Jun 19, 2007 | 11:30 PM
FOMULA91's Avatar
Night!!!
Old Jun 20, 2007 | 10:03 PM
FOMULA91's Avatar
atektuning
May 26, 2011 02:50 PM
FOMULA91
Jul 20, 2007 08:26 PM
islnder102
Sep 22, 2006 01:09 PM
crx_91si
Sep 8, 2003 09:59 AM
