H22 Rev limit
Old Jun 18, 2007 | 12:14 PM
2.2lude88's Avatar
Default H22 Rev limit
I have a jdm h22 with a tuned ecu that has a rev limit of 8200. I have been taking it to 8000. Is that too much?
Old Jun 18, 2007 | 12:51 PM
Finest's Avatar
Default Re: H22 Rev limit (2.2lude88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2lude88 &raquo;</TD></TR><TR><TD CLASS="quote">I have a jdm h22 with a tuned ecu that has a rev limit of 8200. I have been taking it to 8000. Is that too much? </TD></TR></TABLE>
Is this on a stock motor? 8k is a little high for a stock motor with stock cams. You're not making any more hp or torque that high, why stress the motor for nothing?
Old Jun 18, 2007 | 01:04 PM
Prudz_lude's Avatar
Default Re: H22 Rev limit (Finest)
7300 is when your power stops dropping so its pointless to continue to rev the crap out of it.
Old Jun 18, 2007 | 07:25 PM
98vtec's Avatar
moderator emeritus
Default Re: H22 Rev limit (Prudz_lude)
8000 on the stock tach is nothing extraordinary and not beyond the limits of this motor.
Old Jun 18, 2007 | 07:46 PM
marks_lude's Avatar
Default Re: H22 Rev limit (98vtec)
8000 on my stock tach is 7800 anyways.
Old Jun 18, 2007 | 09:04 PM
mattsnooz's Avatar
Default Re: H22 Rev limit (marks_lude)
whats an h23 good for anyhow? whens it stop making power? (stock internals)?
Old Jun 19, 2007 | 05:53 AM
Finest's Avatar
Default Re: H22 Rev limit (mattsnooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">whats an h23 good for anyhow? whens it stop making power? (stock internals)?</TD></TR></TABLE>
6500.
Old Jun 19, 2007 | 06:21 AM
lude98SH's Avatar
personally i felt the power feel like it dropped off slightly after 7k on all stock internals. Thats butt dyno however no sheets to prove that.
Old Jun 19, 2007 | 09:04 AM
NirVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">8000 on the stock tach is nothing extraordinary and not beyond the limits of this motor.</TD></TR></TABLE>
Ditto that. 8000 is more like 7600-7700 on my PIVOT. If youre shifting a stock H22 at redline on the stock tach youre leaving power on the table.
Old Jun 19, 2007 | 10:36 AM
A Blue Lude's Avatar
Default Re: H22 Rev limit (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">personally i felt the power feel like it dropped off slightly after 7k on all stock internals. Thats butt dyno however no sheets to prove that. </TD></TR></TABLE>
No, that makes sense. Torque is dropping off fast on a stock engine before 7000. Power is still around peak, though.
Old Jun 19, 2007 | 11:19 AM
NirVTEC's Avatar
My setup drops about 15tq from 7000-7500rpms.....
Old Jun 19, 2007 | 12:22 PM
M2B4's Avatar
Default Re: H22 Rev limit (:=:NirVTEC:=:)
so where is the best point to shift on stock h22? taking in consideration the ~200 rmp diff on stock tach. 7300 is top of power curve? so shift at 7500 on stock tach?
Old Jun 19, 2007 | 12:23 PM
Finest's Avatar
Default Re: H22 Rev limit (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">so where is the best point to shift on stock h22? taking in consideration the ~200 rmp diff on stock tach. 7300 is top of power curve? so shift at 7500 on stock tach?</TD></TR></TABLE>
Shift at exactly 7563 rpms. Any less and you'll fall out of VTEC on the upshift. Any more and it'll blow up!
Old Jun 19, 2007 | 12:35 PM
I'd go to right below fuel cut. At least in the lower gears.
Old Jun 19, 2007 | 12:42 PM
Prudz_lude's Avatar
Default Re: H22 Rev limit (A Blue Lude)
rofl. Good stuff. shift at about 7500-7600 like stated since the stock tac is off about 200 rpm. power drops off at 7300 and if you shift at 7300 on the stock tac your going to fall out of vtec and loose some time. Shift at 7600 to be safe and you will stay in vtec and always have your power at peak levels.
Old Jun 19, 2007 | 12:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude &raquo;</TD></TR><TR><TD CLASS="quote">always have your power at peak levels.</TD></TR></TABLE>
Yep, you always want to shift to maximize your HP output.
Old Jun 19, 2007 | 12:52 PM
M2B4's Avatar
thats what i thought but wasnt sure the peak of power curve
Old Jun 20, 2007 | 07:22 AM
NirVTEC's Avatar
Shifting at the fuel cutoff is how I ran my fastest times stock. You should be able to catch the 1st sign of bounce, and then shift!
1sickHonda
Aug 20, 2007 10:13 AM
hondaaccord94
Mar 13, 2006 11:07 AM
vietboiracer0
Oct 12, 2005 10:44 AM
jakeiscool
Jun 24, 2005 04:27 AM
ldfolsom
May 24, 2004 11:09 AM
