Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
SLS Shorty, STC Silver Surfer, Tial 38mm Combo Deal. IN STOCK!!! READY TO SHIP!
Old Jun 18, 2007 | 11:04 AM
TTT's Avatar
TTT
Default SLS Shorty, STC Silver Surfer or STC3255, Tial 38mm Combo Deal. IN STOCK!!! READY TO SHIP!
THESE ARE IN STOCK AND READY TO SHIP!!!
SLS Shorty. These have had long lead times, but we have a B-series manifold IN STOCK!!!
We are packaging this manifold with a Speed Trapp Consulting Special Edition Silver Surfer. T04B cover, 60-1 compressor wheel, Stainless Steel Turbine Housing.
This turbo has made 389whp@14psi on a piston/rod upgraded GSR stock sleeve. (14psi by 4200rpms) 400whp@16psi on a Piston/rod upgrade B20/vtec.
Then a silver top Tial 38mm your choice of spring (under 1.0bar).
Combo Special Price- $1500.00 shipped
Turbo only Special- $870 shipped.
Modified by TTT at 12:14 PM 7/19/2007
Modified by TTT at 10:51 AM 7/20/2007
Old Jun 19, 2007 | 12:23 PM
TTT's Avatar
TTT
Old Jun 21, 2007 | 08:53 AM
TTT's Avatar
TTT
dyno coming...
Old Jun 25, 2007 | 02:01 PM
TheShodan's Avatar
Moderator
Default Re: (TTT)
Dynos of the Silver Surfer is coming soon.
These are a 24psi turbo that uses a CORRECT match of the 60-1 wheel and P-Trim turbine wheel, and has a 90 day warranty for the turbocharger. Don't be fooled by the T04b 200-400whp turbos you see elsewhere. These have true results, and use a 1/4NPT feed fitting instead of the 1/8th. Please PM me with questions and specifications so we can find the right combo for you!!
Modified by TheShodan at 2:57 PM 6/26/2007
Modified by TheShodan at 1:26 PM 7/23/2007
Old Jun 26, 2007 | 02:00 PM
TheShodan's Avatar
Moderator
Default Re: (TheShodan)
Silver Surfers are limited.
Old Jul 6, 2007 | 06:06 PM
Schister66's Avatar
Man U FTW
bump for my favorite guys who have helped me out numerous times
TheShodan and SpeedTrapp Consulting....Mac you rule
SLS---just got my new shorty installed earlier today... to Mike
TheTurboTrader because if you're smart enough to befriend these other two guys, you're a good guy
Modified by Schister66 at 8:18 PM 7/6/2007
Old Jul 16, 2007 | 09:11 AM
TheShodan's Avatar
Moderator
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">bump for my favorite guys who have helped me out numerous times
Modified by Schister66 at 8:18 PM 7/6/2007</TD></TR></TABLE>
thanks. in for the bump.
Old Jul 17, 2007 | 09:14 AM
TTT's Avatar
TTT
The STC Silver Surfer is one of the best 400whp street turbos out there. It is for either larger displacement motors or high reving motors. The properly sized turbine wheel is what allows this to happen.
It also uses the PROPER T04B compressor cover, which the compressor wheel was originally was designed for.
Add on the bling of the polished compressor cover and the stainless steel turbine housing and you have got a KILLER combo that JUST PLAIN WORKS!!!
Now if Shodan would just get me the dynos we could post them. There are several 400whp street cars running around with these already. Get yours now.
Old Jul 17, 2007 | 11:48 AM
TheShodan's Avatar
Moderator
Default Re: (TTT)
This turbo is made for those that want to have the quick response of the smaller t3/t04es but don't want to push the limits of them when their motor is built, since now the motor has new "legs". This turbo is good to about 520whp, without the need of large compressor covers, and v-band clamps. One of the perfect upgrades for your current T3/T04b or E.
Modified by TheShodan at 1:01 PM 7/17/2007
Old Jul 18, 2007 | 07:29 AM
Schister66's Avatar
Man U FTW
Great deal on a great setup
SLS Shorty + Silver Surfer = a setup that just plain works
Old Jul 20, 2007 | 07:41 AM
TTT's Avatar
TTT
Schister66
you have inspired me to do a new combo.
SLS Shorty
STC3255
Tial 38mm wastegate
$1350 shipped.
This turbo has made @ 10psi 315whp and 216ftlbs on a STOCK motor GSR!
what do you think Schister66??
Modified by TTT at 10:12 AM 8/30/2007
Old Jul 20, 2007 | 09:29 AM
_Mike's Avatar
B A N N E D
Default Re: (TTT)
Old Jul 23, 2007 | 12:25 PM
TheShodan's Avatar
Moderator
Default Re: (SLS_Mike)
Oh yeah..
Old Jul 23, 2007 | 02:07 PM
_Mike's Avatar
B A N N E D
Old Jul 24, 2007 | 01:41 PM
PSI2HI's Avatar
Former Vendor
Bump for u!
Old Jul 25, 2007 | 08:10 AM
Schister66's Avatar
Man U FTW
Default Re: (TTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote">Schister66
SLS Shorty
STC3255
Tial 38mm wastegate
$1350 shipped.
This turbo has made @ 10psi 306whp and 208ftlbs on a STOCK motor GSR!
what do you think Schister66??</TD></TR></TABLE>
I think that's a great combo, but i would make one slight change to it. I think that you guys should offer (if its feasable) the GT3251 or GT3255 w/ either the B or E housing rather than limiting to just the GT3255. That would allow for the LS and B16 guys to have a nicely matched setup as well as the GSR/ITR guys.
I"ll have new numbers this weekend for everyone...we'll see what this combo is really capable of
Old Jul 26, 2007 | 03:37 AM
Schister66's Avatar
Man U FTW
for anyone who's interested in seeing the GT3255 combo on the same SLS shorty, you can check out this thread....it will also have my new dyno numbers as soon as i'm off the dyno!
https://honda-tech.com/zerothread/2052996
Old Jul 27, 2007 | 11:26 AM
TTT's Avatar
TTT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">for anyone who's interested in seeing the GT3255 combo on the same SLS shorty, you can check out this thread....it will also have my new dyno numbers as soon as i'm off the dyno!
https://honda-tech.com/zerothread/2052996</TD></TR></TABLE>
Dyno numbers are UP!!
314.8whp 216wtq at ~10-10.5psi
Old Jul 27, 2007 | 11:36 AM
Schister66's Avatar
Man U FTW
Default Re: (TTT)
The numbers are up and ready....the best part isn't the peak power though, its the midrange. At 5252rpm where torque and hp cross, i gained 50+whp and 50+wtq over my last setup. You'll see the true comparison once i have the pics loaded....hopefully before the end of the weekend....
Great setup....now there are numbers to back it
Old Jul 31, 2007 | 07:21 AM
TTT's Avatar
TTT
Dynos of the STC3255B are up here:
https://honda-tech.com/zerothread?id=2052996
Old Jul 31, 2007 | 08:40 AM
Schister66's Avatar
Man U FTW
GT3255b and SLS Shorty
great street setup
Old Jul 31, 2007 | 09:21 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I still need to throw my GT3255E up on the dyno, but bump for STC
Old Aug 1, 2007 | 01:15 PM
BobChestnut's Avatar
Default Re: (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">I still need to throw my GT3255E up on the dyno, but bump for STC </TD></TR></TABLE>
quit messin around in DC and NYC and get your stuff done already....i want to see what an ITR engine makes w/ that setup. You'll probably make more than me, but w/e....
Old Aug 5, 2007 | 07:10 AM
Schister66's Avatar
Man U FTW
TTT
Old Aug 5, 2007 | 12:45 PM
b16a4's Avatar
bump
about 1 month i should have a silver surfer dyno!
