Fuel Pump Wire Question!!!
Hey guys i jsut picked up my 1st... 94 accord and was wondering i wanna put a fuel pump kill switch on, and needed to kno which wire (under the fuel pump) i can use to activate my switch too... ??
thnks so much
thnks so much
Use the yellow power wire. However, keep in mind, that if the wire is going to be more then 5 feet, you will beed to install a relay. 5 feet means 2.5ft to the switch, and 2.5ft back. Any longer then that, and you will have too much voltage drop, and a possible lack of flow from the pump, which can lead to a lean condition.
There was a thread about this in the A/S/V forum, i'll try to find the link.
https://honda-tech.com/zerothread/1794938
Edit for link
Edit for link
efking1985
22
Feb 13, 2007 06:58 PM
Mazmay
Aug 16, 2002 12:34 PM
