HELP! battery light won't go out no matter what
Old Jun 18, 2007 | 08:32 AM
senor honda's Avatar
Default HELP! battery light won't go out no matter what
PROBLEM:
With motor running, Battery light/symbol on dash comes on in about 3 seconds and will not go out until motor is cut off. On the way home last night, the volt meter suddenly started reading 17 volts, whether or not headlights were on. I cut off the headlights the last few blocks and drove it home. My battery was dead this morning when I went out and tried to start the car. The battery would only take a charge at it's highest setting:"surge".
Tests I have done so far:
1. Engine starts up and Volt meter almost immediately reads 17 volts, and battery light is on, so............
2. I disconnect the meter ground, and volt meter goes to zero, but battery light stays on with motor running.
3. I unplug the wires/plug on back of alternator, but batt light stays on with motor running.
4. My battery was dead this morning when I went out and tried to start the car.
5. I am charging my spare battery, it has 4 settings: Finished/taper/high/surge.
It has been charging at high for over an hour.
6. With the charger off, I start the car, battery light comes on within 3 seconds.
I reconnect the volt meter ground, it reads 17 volts. Battery light goes off when car is cut off.
WHAT is keeping the battery light on? Any ideas?
Thanks in advance.
Old Jun 18, 2007 | 10:48 AM
sony224422's Avatar
Default Re: HELP! battery light won't go out no matter what (senor honda)
uh. the fact that its 17 volts.
Car systems are 12 volts, not 17. So, its telling you that you are over charging.
Old Jun 18, 2007 | 10:51 AM
TheMuffinMan's Avatar
He knows where you live!
battery light = alternator
alternator overcharging the battery mayhaps?
Old Jun 18, 2007 | 01:15 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Alternator....
Rttix1337
Jan 17, 2014 11:19 AM
Bad_dude
Jan 25, 2011 07:10 PM
uneek4dr
Mar 26, 2006 11:24 AM
Vtecme92
Oct 10, 2005 07:18 PM
