Indicaters of a slipping clutch???
Old Jun 18, 2007 | 07:06 AM
k_lude's Avatar
Default Indicaters of a slipping clutch???
i need to know the indicaters of having a slipping clutch why?? because my second gear falls back when i shift during 7 thousand rpms to around 4-5 thousand rpms...i have a act 6 puck no sprung and the lightest act flywheel...and i do spin tires a little and the clutch does hit hard during then...i would appreciate any info you guys might have not just a yes or no answer.. i would like more in depth answers. and or is it just normal?
Old Jun 18, 2007 | 07:51 AM
SteveoBA8's Avatar
Default Re: Indicaters of a slipping clutch??? (k_lude)
Put it in 5th at a low rpm and floor it, you'll know if it's slipping.
Old Jun 18, 2007 | 10:20 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_lude &raquo;</TD></TR><TR><TD CLASS="quote">i need to know the indicaters of having a slipping clutch why?? because my second gear falls back when i shift during 7 thousand rpms to around 4-5 thousand rpms...</TD></TR></TABLE>
What motor and transmission?
But what you described is normal when you upshift. The rpms drop back down when you shift to a higher gear.
Slipping occurs when the rpms go up but you're not accelerating.
Old Jun 18, 2007 | 10:35 AM
CentralCalLude92's Avatar
How long have you had that clutch set up? If your clutch is slipping your acceleration would be kinda slow while your rpm are moving up rather quickly. You should be able to tell/feel like if there is some lag. but did it do this before or after the ACT setup? In your case it is more likely due too the light ACT flywheel. That flywheel sacrifices inertia loss for very quick throttle response. so that is the reason your rpms drop so low. you gotta shift quicker Thats just my thought. hope that helps.
Old Jun 18, 2007 | 05:19 PM
P13_mein's Avatar
when your H22 feels like an automatic F22 in 100C heat.
Old Jun 18, 2007 | 06:06 PM
projectwidow's Avatar
Default Re: Indicaters of a slipping clutch??? (P13_mein)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein &raquo;</TD></TR><TR><TD CLASS="quote">when your H22 feels like an automatic F22 in 100C heat.</TD></TR></TABLE>
Hey man, nothing wrong with an F22! haha
Do what Steveo said and put it into 5th and floor it and you will see. If the rpms go up and you really aren't moving, time for a new clutch. That's what I did to test out my clutch.
Old Jun 19, 2007 | 08:11 AM
k_lude's Avatar
Default Re: Indicaters of a slipping clutch??? (projectwidow)
when i put it in fifth the rpm and speed gauge are evenly normal...when i hit the gas its response is still very strong and picks up speed quickly..i was thinking traction problems and now i know it is...cause my shifts are faster then the blink of an eye so it must be the tires..thanks everyone.
Old Jun 19, 2007 | 08:19 AM
M2B4's Avatar
the 5th gear test is if it instantly dies ur clutch is fine it it takes a second ur slipping. im driving on a slipping and ull know if thats what it is when i go into vtec and redline and shift it kinda chills at 6k for a few seconds b4 it catches.
turbo-crx
Sep 15, 2008 01:23 PM
98R-1144
Jun 27, 2008 07:40 AM
ablack934doorcivic
Nov 1, 2005 02:02 PM
gsr camel
Nov 17, 2001 08:18 PM
FlipboiGSR
Sep 12, 2001 09:07 PM
