Apr Head studs. Same for GSR and Type R?
I have a b16b block which as we all know is a destroked teg type r engine. So i got APR head bolts for a teg r engine.
I am now getting a b18c4 block which is the same as a b16a2 block. Can i use the same head studs? I will be using the b16b head with b18c4 block. Is this alright?
Are they interchangeable between the b16 and b18 blocks and heads?
HELP PLEASE
Josh
HELP PLEASE
Josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J1A1H »</TD></TR><TR><TD CLASS="quote">I have a b16b block which as we all know is a destroked teg type r engine. So i got APR head bolts for a teg r engine.
HELP PLEASE
Josh</TD></TR></TABLE>
fwiw, b16b + b18c blocks are all the same, ive never heard of a b18c block sharing the same deck hight as a b16a block.
you should be able to use them studs on your b18c(as it should be the same block as the b16b)
HELP PLEASE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J1A1H »</TD></TR><TR><TD CLASS="quote">hmmm ok... But i heard that the b18c and c4 or known as the GSR motor is the same block as a b16a2 just with a 1.8 stroke...???</TD></TR></TABLE>
nope. only the b16b shares deck heights with b18's. b16a's are shorter.
match the studs to the block
allmotorcrx415
Sep 28, 2006 04:03 AM
SpoonEk253
Apr 14, 2006 04:35 PM
