Need Help Deciding spring rate Preference (GC/Koni Yellows owners)
Old Jun 17, 2007 | 10:28 PM
HenryTypeS's Avatar
Default Need Help Deciding spring rate Preference (GC/Koni Yellows owners)
Hey guys, im in the middle of TRYING to find my personal preference for my set up. before i order my GC's can you guys post up your:
1. spring rate (front/rear)
2.and a description on how it feels, handles, and understeer/oversteer, etc. a
any info thats helpful will be greatly appreciated. thanks very much.
i personally want to be able to drive the car everyday. i can handle a rough ride to an extent. not sure what the limit is yet tho.
i would love the car to handle like a beast too.
so if you would please post your set up and you opinoin on it also. and if u could change your rate. would you? and why.
agian thank
i already searched too. picked up alot of good info. but didnt find a list of ppls opinoins
Old Jun 17, 2007 | 10:31 PM
vteclude07's Avatar
Default Re: Need Help Deciding spring rate Preference (HenryTypeS)
front 1" 1/2. rear 2" 1/4... no more
Old Jun 17, 2007 | 10:38 PM
HenryTypeS's Avatar
Default Re: Need Help Deciding spring rate Preference (vteclude07)
spring rates. not height.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteclude07 &raquo;</TD></TR><TR><TD CLASS="quote">front 1" 1/2. rear 2" 1/4... no more</TD></TR></TABLE>
and am i trippin or is ur rear lower then ur front?
Old Jun 17, 2007 | 10:49 PM
vteclude07's Avatar
nooo. my bad i misunderstood u and i still dont understand.. stock comes with high[er] rear.. thats how much i lowered mine
Old Jun 17, 2007 | 10:51 PM
vteclude07's Avatar
my feel ok. but i feel every bump when i drive:/
Old Jun 17, 2007 | 11:48 PM
HenryTypeS's Avatar
gotcha. but the springs i want come in multiple rates... i read alot on it. but cant seem to find waht im really lookin for. im on google. wiki.. searching hella....
Old Jun 18, 2007 | 12:21 PM
avallach's Avatar
Unless you plan to take the car to the track or autox it, the OTS (380F/275R) rates are a good compromise between comfort and handling. With the Koni's adjustable rebound, you've got some room for experimentation. Add a thicker rear sway bar while you're at it.
Old Jun 19, 2007 | 06:58 AM
Halo's Avatar
Default Re: Need Help Deciding spring rate Preference (avallach)
How low do you plan on going? The lower you go the stiffer the spring rate you will need. Remember the Prelude is a heavy car..I ended up going with 550 front and 450 rear using a 7" spring.
Old Jun 19, 2007 | 11:36 PM
HenryTypeS's Avatar
Default Re: Need Help Deciding spring rate Preference (Halo)
i want to line the tire and the fender up. the wheels are RSX type S.
17 inch. i think 215 full diameter and i think 45 side wall. i forgot. stock rsx-s (2006)
and i would like to get into autocross too. i just want a handler.... thanks for everyones help so far tho
Old Jun 20, 2007 | 01:30 PM
2-7offsuit's Avatar
I'm rocking 700f 800r with KPSS3 Konis. It turns great. Feels really neutral. It's pretty damn stiff for daily driving though. I'll probably be going to something softer soon. Maybe 450f/r with a thicker rsb.
Old Jun 20, 2007 | 02:10 PM
vinuneuro's Avatar
Default Re: (2-7offsuit)
Whatever you decide, for street use you're better off running a slightly lower rate in the back than front, and adding a thicker sway bar.
Old Jun 20, 2007 | 02:13 PM
E-Money's Avatar
Default Re: (vinuneuro)
why dont you look into a rear sway bar for handling. eibach pros and koni yellows is more than plenty on full stiff for anyone for street driving... and for auto-x why not go with a 16 inch rim?
Old Jun 21, 2007 | 11:41 AM
shaylude's Avatar
Default Re: (E-Money)
for daily driving how do the koni yellows/gc's feel?
bnetkillzone
Suspension & Brakes
75
Feb 15, 2012 11:47 AM
dirtyharryhatch
Suspension & Brakes
12
Jun 23, 2010 01:34 PM
cleen
Suspension & Brakes
17
Apr 25, 2010 04:52 PM
2ndgent3g
Aug 29, 2007 07:55 PM
mikeycivic
Suspension & Brakes
Apr 3, 2007 07:29 AM
