dc4 dash swapped, turn signals and heat dont work??
Old Jun 17, 2007 | 09:21 PM
odishaw's Avatar
Default dc4 dash swapped, turn signals and heat dont work??
hey
just did a dash swap into my dc4.plugged everything back in.
when i tested it, the turn signals dont work and also the heater dont work either!
fan works just no hot air (checked the turn signal fuse looks fine)
any suggestions?
thanks
Old Jun 18, 2007 | 08:03 PM
odishaw's Avatar
Default Re: dc4 dash swapped, turn signals and heat dont work?? (odishaw)
cmonn guys need help!!!signal lights wont work?? did dash swap from tan to black plugged wires in and the signals wont work..and to top it off now my heater wont work? fans work but no heat... someones gotta know something about this.. help me out!!!
thanks
Old Jun 18, 2007 | 10:43 PM
Dc2Point2's Avatar
Your on your own on this one JK. Retrace your steps check if you left something unplugged sometimes if you leave something unplugged other components may stop working.
Old Jun 19, 2007 | 12:07 AM
1.8L_allmotormilitia's Avatar
your spoon avatar is messed up...fix it.
Old Jun 19, 2007 | 01:23 AM
BlueIntegraBoy's Avatar
Make sure all the subharnesses are plugged in. As for the turn signals, make sure the hazard switch is plugged in.
Old Jun 19, 2007 | 08:03 PM
odishaw's Avatar
Default Re: dc4 dash swapped, turn signals and heat dont work?? (BlueIntegraBoy)
ok so got the heater working.. and as for the turn signals the hazard work when u turn them on.. the lights blink.. but still when u turn the turn signal on, no lights turn on nor does the cluster light blink or does the blinking noise occur...any more ideas?
sorry my avatar sucks k.. lol
Old Jun 19, 2007 | 11:06 PM
Dc2Point2's Avatar
Did you short something out while swapping out the dash? recheck all your fuses, and check the turn signal relay. How did you get the heater to work? did you leave something unppluged, or loose connections?
Jose Gomez
Nov 9, 2023 06:34 PM
mac_24_seven
Mar 13, 2012 03:34 AM
gwchndlr
Mar 18, 2007 03:17 PM
hanskies
May 29, 2006 05:29 PM
aktc167
Sep 2, 2005 10:08 AM
