dohc zc swap sputtering
Old Jun 17, 2007 | 06:40 PM
extensioncordy's Avatar
Default dohc zc swap sputtering
i just put a dohc zc in my hatch (which has been converted to mpfi along time now)
it starts and idle great. but when i go to give it gas it falls on its face and then it rev's up. and if i slightly rev it to like 2k and then go to give it full throttle it falls on its face and drops to like 1500 and then revs up fine. i havent driven it yet due to no bitch pin but i cant figure out whats causing this.
Old Jun 17, 2007 | 07:02 PM
JKingCivicSi's Avatar
Default Re: dohc zc swap sputtering (extensioncordy)
Does it only do this when cold? Mine kinda does the same thing when cold and I just havent got around to really investigating it. Someone did recommend that I check valve lash, but I havent done that yet. Writeup on valve adjustment here.
Also try posting at:
http://www.thezcr.com
I'm interested in what you find out too.
Old Jun 17, 2007 | 07:06 PM
Loaded Butane's Avatar
Your timing belt may be off a tooth. My ZC acted like that when mine was off.
Old Jun 18, 2007 | 09:48 AM
replaced the tps but didnt adjust it and it runs a little better. still rough
DOHC_EF
13
Jun 4, 2004 09:39 PM
DesiDez
Jun 10, 2003 12:41 PM
pelotudo
Sep 30, 2002 06:18 PM
MR CRX
Aug 15, 2002 08:36 PM
