Suspension & Brakes Theory, alignment, spring rates....
top hat spacers?
Old Jun 17, 2007 | 05:38 PM
huge230's Avatar
Default top hat spacers?
Is it possible to use some sort of a top hat spacer between the top hat and the strut tower for a little extra ride height?
I am sitting pretty low and dont know if I can even get out of my driveway lol
Old Jun 18, 2007 | 07:47 AM
beav's Avatar
Default Re: top hat spacers? (huge230)
i have thought about this. i was on H&R race springs and i wanted to keep them because i liked the spring rate, but i wanted to be a little higher up. i found no such spacers, the only thing you can do is make your own, depending on how thick you want to make them. keep in mind if you make them too thick, you wont have enough room on the stud to tighten the nut.
one way of making them is to use the top ring of a spare set of bootlegged coilovers. just break off and drill out the studs on their top hat. or if they dont have studs, just mark off where they would be and drill through.
another way is to take off your existing top hat and take it to a metal shop and tell them to fabricate you a set. should be no problem. just tell them to use something that wont rust, like galvanized metal.
Old Jun 18, 2007 | 09:39 AM
huge230's Avatar
Default Re: top hat spacers? (beav)
thanks. Is it safe to use a small spacer like in the coilover example you mentioned?
Old Jun 18, 2007 | 12:37 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to use some sort of a top hat spacer between the top hat and the strut tower for a little extra ride height?
I am sitting pretty low and dont know if I can even get out of my driveway lol</TD></TR></TABLE>
Any spacer there will not provide additional shock travel, just a higher ride height. If you're so low you can't get out of a driveway, I don't see how you could drive the car without bottoming the shocks all the time.
Taller springs, shocks with a higher spring mount, or a spring spacer, might be better to look into instead of spacing the upper spring/shock mount from the chassis.
Old Jun 18, 2007 | 04:29 PM
huge230's Avatar
Default Re: top hat spacers? (TunerN00b)
well its so low because it a H22 in an Eg with a 3 inch downpipe. I have exactly 3.25inches from the ground to my downpipe and my driveway is a bitch but maybe ill just have to give it a shot anywho.
Old Jun 18, 2007 | 06:13 PM
TEGNO1's Avatar
Here are some pics of what you can do
If you go too thick you will need longer wheel studs.
For more travell
Old Jun 18, 2007 | 11:53 PM
importdude2000's Avatar
Default Re: top hat spacers? (TEGNO1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEGNO1 &raquo;</TD></TR><TR><TD CLASS="quote">Here are some pics of what you can do
For more travell
nice wgho makes em?
im just wondering
Old Jun 19, 2007 | 12:41 AM
TEGNO1's Avatar
I just had em cnc'ed out of billet alloy.
Old Jun 19, 2007 | 04:03 AM
huge230's Avatar
Default Re: (TEGNO1)
wow looks good. thanks
lerks909
Aug 21, 2014 10:09 AM
MSchu
Suspension & Brakes
Jan 28, 2009 08:18 AM
CBEengineering
Suspension & Brakes
Dec 21, 2006 11:34 AM
Audio28
Feb 15, 2003 02:55 PM
