CRX wheel/tyre combo for drag racing?
Old Jun 17, 2007 | 02:44 PM
djnikko's Avatar
Default CRX wheel/tyre combo for drag racing?
As the title says im looking to kit my 89 shape CRX out with some slicks and wheels. Im looking to put down ~400hp at the wheel and the car is just for straight lining. I am not bothered about the rear wheel/tyres combo just yet.
Will 13's fit over stock sized brakes? If so should I be looking at a 7" or 8" wide wheel? I wanted to avoid 15" wheels if possible as I wanted to keep the ride height as low as possible, and wanted to avoid 14"'s as slicks are rare in that size. If anyone can chime in and give me some pointers that would be great.
Old Jun 17, 2007 | 03:11 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: CRX wheel/tyre combo for drag racing? (djnikko)
Yes the 13's will fit. and are your best choice in diameter..
for 400hp, id suggest an M&H 25x8x13 or a Mickey Thomson 24.5x13x8.. thats pretty much it....
Old Jun 17, 2007 | 03:18 PM
djnikko's Avatar
Default Re: CRX wheel/tyre combo for drag racing? (SIXTYdashONE)
Nice one, thankyou! what width would you recommend for that tyre size? Is there a rough offset I should bear in mind when picking the wheels? Im from the UK so tech knowledge on that particular application is hard to come by
Old Jun 17, 2007 | 03:41 PM
HT's Biggest Loser
Well the width of the tire is included in my above post..
For Example ...........24.5 X 8 (width) x 13 (rim size)
cheers!
Old Jun 17, 2007 | 05:51 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">Well the width of the tire is included in my above post..
cheers!</TD></TR></TABLE>
He asked for TYRE sizes dumbass!!!! lol
Old Jun 17, 2007 | 05:59 PM
HT's Biggest Loser
Default Re: CRX wheel/tyre combo for drag racing? (Boostfed.com)
Well WTF, i guess the Tyre width is a little different.. let me check the spec sheets
Old Jun 18, 2007 | 04:18 PM
djnikko's Avatar
Thanks for your replies, I hear its ok to run an inch either way when it comes to tyre size. Would you suggest a 7 or 8" wide wheel? and if so is it as easy as just matching the tyre width up or should I look to run slightly wider. For example 13 x 7" wheel, and 8" wide tyre?
Cheers
Old Jun 18, 2007 | 04:28 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your replies, I hear its ok to run an inch either way when it comes to tyre size. Would you suggest a 7 or 8" wide wheel? and if so is it as easy as just matching the tyre width up or should I look to run slightly wider. For example 13 x 7" wheel, and 8" wide tyre?
Cheers </TD></TR></TABLE>
Get the wider wheel if you can.
Old Jun 18, 2007 | 04:48 PM
HT's Biggest Loser
what he said....
Old Jun 18, 2007 | 04:49 PM
Jared's Avatar
for boostfed, always giving advice, but never racing
Old Jun 18, 2007 | 04:54 PM
HT's Biggest Loser
Default Re: CRX wheel/tyre combo for drag racing? (Jared)
what about me then, lol....
Old Jun 18, 2007 | 05:20 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE &raquo;</TD></TR><TR><TD CLASS="quote">what about me then, lol....</TD></TR></TABLE>
all three of us, lol
Old Jun 18, 2007 | 05:22 PM
Boostfed's Avatar
New User
The 3 MuskuE-Racers FTW!
Old Jun 18, 2007 | 05:23 PM
HT's Biggest Loser
lol... not after your long weekend of slavery on your car...
well unless you break some ****.. then you can sit back on the bench
__________________________________________________ ________
OK so this thread doesnt go to total hell. to the original poster, id suggest a wider wheel... id go with an 8' width.. but thats just me... It makes the most sense to me as far as creating the largest (in this case, width) contact patch on the ground...
Old Jun 19, 2007 | 03:40 PM
djnikko's Avatar
Thanks much appreciated for your help
honda tech does have tech
rudebwoy
Apr 11, 2010 12:46 PM
djnikko
Jun 17, 2007 02:38 PM
Pinhead
Apr 11, 2002 03:53 PM
Hondasaurs
Nov 6, 2001 09:58 AM
