"Rubber" Socket.
Old Jun 17, 2007 | 02:40 PM
mtny's Avatar
Default "Rubber" Socket.
I've been calling around trying to find a 19mm socket that has a rubberized inner coating, to prevent scratching my extended Rays lugs. I could have swore that Harbor Freight had them but they said nope. Anyone know where I can find some?
Thanks in advance.
Old Jun 17, 2007 | 02:59 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: "Rubber" Socket. (mtny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtny &raquo;</TD></TR><TR><TD CLASS="quote">I could have swore that Harbor Freight had them but they said nope.</TD></TR></TABLE>
They lied. Probably just from ignorance. I bought a set in one of their stores, so I know they usually stock them.
Ask for their item number 40036-1VGA (for 17/19/21 mm, $8.99) or 40035-3VGA (also includes 13/16'', 7/8'', 1'' & 1-1/16'', $24.99). Click on photo for more info.
If you want to spend a whole lot more money ($59.99) for a set that also includes a 22 mm and a six-inch extension, you can get this one from Griot's Garage (item 10208):
Old Jun 17, 2007 | 06:20 PM
mtny's Avatar
Default Re: "Rubber" Socket. (nsxtasy)
I knew they had them! Maybe they were out of stock. Thanks man.
Old Jun 19, 2007 | 11:33 AM
Mike K's Avatar
matco also makes a set of aluminum insert sockets for delicate fasteners.
Old Jun 19, 2007 | 07:57 PM
Leftbraned's Avatar
You can also be really cheap and do what we do at work, double over a plastic grocery bag on the lug and slide the socket over carefully, then remove or install using HAND tools.
If you are careful you should have no problems removing and installing the lugs with this no cost solution. (Remember your lugs should only be at about 80-85 ft/lbs.)
Old Jun 20, 2007 | 06:33 PM
Bailhatch's Avatar
Default Re: (Leftbraned)
Ya, putting something over the nut it the way to go. All those sockets posted above will protect your <U>wheel</U>, not the lugnut.
Old Jun 20, 2007 | 07:25 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">All those sockets posted above will protect your <U>wheel</U>, not the lugnut.</TD></TR></TABLE>
Not true.
Obviously you didn't bother clicking on the photo to read about them...
Old Jun 21, 2007 | 11:42 AM
Bailhatch's Avatar
Default Re: (nsxtasy)
yup that is obvious.
sorry, just never seen them with a liner. good find
Old Jun 22, 2007 | 07:06 PM
Frator's Avatar
Actually if you talk to your local Snap-On guy, I'm sure Matco or Mac Tools has the same thing, he should be able to hook you up. A friend of mine also has the Rays extended lugs on his 07 Si and he bought a socket from one of our local Snap-On guys that has a hard plastic liner that won't jack up his lugs. Also it is thin walled to help protect the wheel. It was $28 bucks.
.:Made in OC:.
18
Sep 25, 2006 06:53 PM
95dc2
Honda S2000
13
Mar 2, 2006 02:06 PM
EG_Civic_Si
Feb 28, 2006 07:37 PM
Psychedelicone
Jul 8, 2005 01:52 PM
civickidd99
Sep 13, 2003 12:46 PM
