New transmission and Axles, now theres vibrating?
Old Jun 17, 2007 | 02:17 PM
95dc2teg's Avatar
Default New transmission and Axles, now theres vibrating?
I just had my new type R tranny and new axles installed on my 95 integra gsr. Now from accelrating 2500 to 4000 rpms in second and third gear the front end of the car vibrates. What could it be? axles installed wrong? maybe i need an alignment?
Old Jun 17, 2007 | 02:58 PM
g0tgot's Avatar
Default Re: New transmission and Axles, now theres vibrating? (95dc2teg)
i have no idea is it a hopping is there trani grind? what does the clutch feel like? is there any whining>>? or is it just vibrating?
Old Jun 17, 2007 | 03:34 PM
95dc2teg's Avatar
Default Re: New transmission and Axles, now theres vibrating? (g0tgot)
there is no hopping, and no grinds, the tranny shifts perfect, clutch feels normal. the front end just vibrates/shakes accelrating normally between 2500-4000rpms. it feels lik something is loose but after 4k the vibrating/shaking goes away. I havent had an alignment in quite a while but its weird cuz it never did it before the new axles and tranny
Old Jun 17, 2007 | 03:36 PM
Dartanian's Avatar
Where did you buy the "new" axles? Chances are it is a POS remanufactured one with a blown CV joint.
Old Jun 17, 2007 | 03:39 PM
Ari's Avatar
Ari
* B A N N E D *
Default Re: New transmission and Axles, now theres vibrating? (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian &raquo;</TD></TR><TR><TD CLASS="quote">Where did you buy the "new" axles? Chances are it is a POS remanufactured one with a blown CV joint.</TD></TR></TABLE>
Very good chance of that happening , or else my guess would be somthing wasnt installed correctly , take the time to go back and triple check everything on both ends.
Old Jun 18, 2007 | 06:36 PM
TEGHEAD's Avatar
DID YOU EVER FIND OUT WHAT THE PROBLEM WAS MY CAR IS DOING THE SAME
Old Jun 18, 2007 | 07:23 PM
95dc2teg's Avatar
Default Re: New transmission and Axles, now theres vibrating? (TEGHEAD)
no i havent found out yet. I am going to my mechanic tomorrow to see whats up. hopefully it gets resolved. I will let you know what my problem is.
Old Jun 18, 2007 | 08:58 PM
martyball619's Avatar
%100 axle problems
Old Jun 18, 2007 | 10:56 PM
GSR-TRBO-DA's Avatar
had a similar problem for a while in my ek. changed everything, all the time it was the axle. i changed both of them and never looked back. first find out what side it comes from then go from there
1bar_ek
May 18, 2008 04:44 PM
jordanb1
Dec 26, 2005 08:58 AM
b18-c-rx
Apr 18, 2005 07:26 PM
TypeRod
Aug 21, 2002 10:48 PM
KingJB
Jun 18, 2001 01:48 PM
