EG/DC camber fit into an EF
Old Jun 17, 2007 | 12:53 PM
Mr.Milton's Avatar
Default EG/DC camber fit into an EF
Can a EG/DC camber kit fit into an EF with some modification..? don't wan't the bushing ones, interested in the A-arm ones.
Old Jun 17, 2007 | 01:06 PM
nihad's Avatar
Default Re: EG/DC camber fit into an EF (EF8-B18C)
they are diff i belive i looked at pics at honda delership.
Old Jun 18, 2007 | 10:02 AM
Mr.Milton's Avatar
Default Re: EG/DC camber fit into an EF (nihad)
bump
Old Jun 18, 2007 | 10:10 AM
fireant's Avatar
Front will definitely not fit.
Old Jun 18, 2007 | 10:49 AM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8-B18C &raquo;</TD></TR><TR><TD CLASS="quote">Can a EG/DC camber kit fit into an EF with some modification..? don't wan't the bushing ones, interested in the A-arm ones. </TD></TR></TABLE>
the mounting point is very off.
jhpusa.com sells a pair that work for 90-91 integras and EFs but they are expensive, like $439 IIRC
Robearracing.com has the REVO piece which works for 88-91 civics and integras, and is like $180
also, its worth noting that 88-89 crx's have welded upper ball joints, so the a-arm must be replaced when doing a ball joint, just learned that this weekend too.
90-91 upper a-arms have press out ball joints, and are upgradeable.
Old Jun 18, 2007 | 10:58 AM
Mr.Milton's Avatar
Default Re: EG/DC camber fit into an EF (doublethink)
thanks
Old Jun 18, 2007 | 12:25 PM
Mr.Milton's Avatar
bump
Old Jun 18, 2007 | 12:36 PM
nihad's Avatar
why not just get some rhino or revo front cambers they are cheap and adjustable fits the ef. you can get them off ebay. The rhino is like 75 really cheap.
Old Jun 19, 2007 | 12:28 PM
Mr.Milton's Avatar
bump
Old Jun 19, 2007 | 02:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8-B18C &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
Sigh. What happened you got a set of EG ones for free so your going to reinvent the wheel?
why did you bump this again?
EG/DC UPPER A-ARMS WILL NOT FIT.
ITS OFF BY A LOT.
They can't be modded since its a vital suspension part containing the upper ball joint.
Get the correct part or don't slam the car.
Old Jun 19, 2007 | 05:12 PM
Tyson's Avatar
just because you bumped this multiple times, im going to yell at you too.
WTF DONT YOU UNDERSTAND? THEY DO NOT FIT.
Mac
Jul 26, 2006 04:08 PM
JDM Panda
Aug 3, 2005 02:48 PM
DJ_SaNdOz
Sep 8, 2003 05:34 PM
JDMCRX
May 25, 2003 07:12 PM
