skunk ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @JDM_Gsr »</TD></TR><TR><TD CLASS="quote">k i need to convert to OBD-1 right?</TD></TR></TABLE>
you just need jumper wire for your ecu. couple places carry them. obd2b to obd1 and obd2a to obd1.
http://www.jhpusa.com
http://www.jdmshit.com
That guy can't even spell and you want to buy something from him??
92-95 CIVIC SKUNK2 ECU
HI,THIS IS A PERFORMANCE UPGRADE ECU.THIS ECU <U>ARE</U> PROFESSIONAL INSTALL.YOU ARE BUYING A COMPLETE ECU WITH BUILD IN CHIPS AND KIT INSIDE ALREADY,<U>SO THERE WILL NO INSTALLATION REQUIRE ALL YOU NEED IS TO PLUGS THIS ECU INTO YOUR CAR AND RUN</U>.THIS <U>ECU ARE WELL </U>TESTED INTO THE CAR.100% SURE ALL THE ECU AND QUALITY ARE PROFESSIONAL.IT ALL GUARANTEE FOR 2 WEEK (DOA) OF PERIOD OF TIME.WARRANTE FOR REPLACE FOR ANY WORKMAN SHIP. THIS ECU WILL GIVE YOU MORE POWER WITH EXTRA BOOST AND QUICKER ACCERATION.YOU WILL EXPECT OF ALOT OF POWER GAIN.INCREASE OF WHEEL TORQUE(HAHAHAHASorry).FOR MORE INFO YOU COULD CONTACT ME OR LOOK UNDER FOR THE SPEC AND WHAT ECU WILL FIT.
Spec: P28 SKUNK2 SPEC
VTEC AT 4,800 RPM
RELINE LINE 9,200 RPM
INCREASE UP TO 20 + HP NO FUEL CUT OFF NO REV LIMITER 5speed m/t used only
VTEC AT 4,800 RPM
