Advice: Wiring JDM 1-piece headlights
Old Jun 16, 2007 | 06:20 PM
distronic's Avatar
New User
Default Advice: Wiring JDM 1-piece headlights
I've got a '90 Integra (DA?) RS 4-door. I got some genuine JDM 1-piece headlights that I would like to replace my current 3-piece ones with. Questions: 1) What kind of bulbs do these headlights use, and 2) What are some ways I can go about rewiring the JDM headlights to work with the existing wiring? I am not afraid to solder or anything, but if I could do something non-invasive, that would be great. Thanks for all the help!
Old Jun 16, 2007 | 07:49 PM
superchi's Avatar
The JDM DA headlights use H4H headlight bulbs, the fogs and corner are the same, H3 and 194.
I think the only thing you'll need to alter is the headlight bulb harness, you'll just cut the original USDM headlight bulb harness and wire in the JDM harness. For the corner, you'll only use one harness instead of the two like the USDM corners. You'll probably want to use the harness that blinks and then tuck the other one away or use it for the JDM sidemarkers.
I'm pretty sure that's the way to go, anyone correct me if I'm wrong. The only reason I'm not certain is because I didn't get a chance to put my one piece headlights on my DA before the motor blew
Old Jun 17, 2007 | 09:59 AM
distronic's Avatar
New User
Default Re: (superchi)
Great. Thanks bro. I was initially going to do an HID retrofit but money wore thin and I am just going to but these headlights in for the time being.
Old Jun 17, 2007 | 10:29 AM
RenzoDaPlayboi's Avatar
Default Re: (distronic)
the wiring is on g2ic.com...in the teg tips section...that should get u goin
Old Jun 17, 2007 | 02:19 PM
Bro. Darkness's Avatar
Default Re: (RenzoDaPlayboi)
i used the g2ic instructions and after installing and testing the first headlight, my low beams do not work. any suggestions on what the prob could be?
Old Jun 17, 2007 | 02:52 PM
Default Re: (Bro. Darkness)
check the fuses
Old Jun 18, 2007 | 04:25 AM
dammit! last night on the way to work i noticed my foglights dont work either....switch onthe dash doesnt even light up. bout to go check the fuses though
Old Jun 18, 2007 | 04:36 AM
damn i must get the dumbass of the year award! it was the fuse but what about the foglights?
Old Jun 18, 2007 | 04:55 AM
did the fogs light up then stop working?
Old Jun 18, 2007 | 05:07 AM
they worked while we were wiring in the jdm headlight but after we had the headlight working we noticed the usdm foglight wasnt working (getting jdm plug adapters today)
Old Jun 18, 2007 | 05:08 AM
how do u have a usdm fog with a jdm headlight?
Old Jun 18, 2007 | 05:11 AM
lol nah i havent installed the pass side jdm 1 peice yet. so i have a 1 peice on the drivers side with the fog not plugged in and a usdm on the other side with the fog still pugged and not working.ghetto as funk....i know.
Old Jun 18, 2007 | 05:15 AM
hmm...but what is your reason for not installing both jdm headlights? and it is easy to wire the fogs...it is only 2 wires...power and ground
Old Jun 18, 2007 | 05:21 AM
ran out of wiring connectors and i work night shift so i pretty much sleep all day but ill probly finish today since im actually still up
Old Jun 18, 2007 | 05:24 AM
why dont u just splice it and tape it up?
Old Jun 18, 2007 | 05:28 AM
i might do that just to see if everything works but my buddy has connectors and plug adapters and i would feel more comfortable doing it that way than just splicing and taping it. it all worked fine for him in his 91 DA. plus i have a bad tendency to run into bad luck so i want to use the most fool proof method
Old Jun 18, 2007 | 05:29 AM
true...well let me know how everything turns out
Old Jun 18, 2007 | 05:30 AM
yea man, thx
Old Jun 18, 2007 | 06:14 AM
hb420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenzoDaPlayboi &raquo;</TD></TR><TR><TD CLASS="quote">why dont u just solder it and tape it up?</TD></TR></TABLE>
fixed.
Old Jun 18, 2007 | 11:02 AM
both headlights are in. ill post up some pics soon.
Old Jun 18, 2007 | 12:21 PM
distronic's Avatar
New User
Hey Bro. Darkness, where can I get those plug adapters for the headlights? I don't really wanna cut wires if necessary. Thanks!
Old Jun 18, 2007 | 12:34 PM
passwordjdm.com
Old Jun 18, 2007 | 12:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenzoDaPlayboi &raquo;</TD></TR><TR><TD CLASS="quote">passwordjdm.com</TD></TR></TABLE>
bam! there ya go. problem solved man,
Old Jun 19, 2007 | 05:44 AM
wish i had a night pic but oh well
it looks like a funkin monster truck right now so hopefully i can go ahead and put these on...
lilazn71
Oct 13, 2007 11:38 AM
mystikteg92
May 16, 2005 08:58 AM
92nb
Jul 28, 2004 12:50 AM
blklude
Jun 17, 2003 09:34 PM
knightlude
Jun 13, 2003 06:06 PM
