B18C1 Low Idle, High Temp, Rebuilt Motor
Old Jun 16, 2007 | 11:14 AM
integrainside's Avatar
Default B18C1 Low Idle, High Temp, Rebuilt Motor
Just got finished rebuilding a B18C1 and i start it up and it sounds perfect, im very happy. Then as it starts to warm up, after bout 5 min of idle, the rpm drops to like 300 and it is just barely stayin alive. Now the weird thing is it never did this before and i didnt even touch anything on the head or intake manifold, just took it off and back on. Also it could just be me but it seems like the valve cover is getting unusually hot. Any advice would be greatly appreciated!
Old Jun 16, 2007 | 01:40 PM
dbiker207's Avatar
Default Re: B18C1 Low Idle, High Temp, Rebuilt Motor (integrainside)
did the temp guage read hot?
Old Jun 17, 2007 | 01:02 PM
Default Re: B18C1 Low Idle, High Temp, Rebuilt Motor (dbiker207)
No, thats the strange part... the temp gauge was not even midway yet and the valve cover was so hot i could barely touch it without getting burnt.
Old Jun 17, 2007 | 03:38 PM
dbiker207's Avatar
feel the top and bottom radiator hoses with the car up to temp, see if they are both hot
Old Jun 17, 2007 | 11:04 PM
Yes they are both hot, but the bottom one is not as hot and takes alot longer to get there... The coolant temp gauge says i am good, i just dont understand.
Old Jun 18, 2007 | 04:21 PM
Any ideas? I really need help on this
Old Jun 18, 2007 | 04:52 PM
dbiker207's Avatar
is the water pump new with the rebuild? it sounds like the water pump isnt pumping.
Old Jun 18, 2007 | 08:15 PM
yes the water pump is new
Old Jun 19, 2007 | 05:08 PM
oldguy03's Avatar
Did you set the base timing?
mkentrup3589
Honda Civic (2001 - 2005)
Feb 5, 2016 01:25 AM
crxguy406
Apr 17, 2013 06:47 PM
cafine
Dec 17, 2009 02:37 PM
kevprelude
Jun 8, 2009 10:34 PM
otakueric
May 6, 2004 07:17 PM
