how many quarts
Old Jun 16, 2007 | 09:17 AM
frankie11's Avatar
Default how many quarts
I searched and didnt find this answer. How many quarts of oil should be put in a ITR engine? and on the dip stick the oil level should be between the two holes? The reason I asked this is because I had a place change my oil and they filled it pass the top hole on the dip stick, hopefully they did not over fill it. thanks
Old Jun 16, 2007 | 09:51 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: how many quarts (frankie11)
It takes 4.2 quarts to change the oil, including changing the filter.
The distance between the two dots is a difference of one quart. As long as the oil level is anywhere between the two dots, you're okay (but it's better to keep it near the top dot to reduce the chances of it getting too low). I wouldn't worry if it's 1/4 quart overfilled (IOW, if it's over the top dot by 1/4 the distance between the two dots), but I would consider draining some if it's overfilled by 1/2 quart or more.
Zaraki
14
Jun 2, 2011 03:21 PM
JDMpride
Nov 27, 2010 06:58 AM
vinuneuro
Mar 15, 2005 04:41 PM
davejj40
Nov 27, 2004 08:08 PM
94GsRacer
Sep 19, 2002 02:43 PM
