Need theory on what's wrong with my tranny
Well,
I bought a tranny and installed LSD in it. Slapped on the new clutch, throw-out bearing, etc. bled the clutch line, pedal is nice a firm...
- So the problem is, when the car is in neutral and not running, i press the clutch in and start the car. While the car is running and I try to put it in gear, it won't go in gear. so I turn is off and run through the gears with the car off, it shifts easily into each gear.
- So I started the car in neutral again, would not go in to geat
- turned the car off, put it in reverse and pressed the clutch in and tried starting the car while it was in gear and it jumps.
-so, i know it's more than likely something simple. can someone point out to me what's wrong. thanks
it's a competition clutch twin disk with it's own flywheel, it's brand new. What do you think I should do?
Modified by MardreRacing at 8:13 PM 6/16/2007
i really dont know much about the cm twin disk. i would start by taking the release bearing fork and see if it feels really loose. your gonna have to remove the slave cylinder to feel the play in it.
southernSCHEME
Dec 4, 2009 02:09 PM
DC209
31
Dec 6, 2007 09:11 AM
Project_ED8
Sep 12, 2004 07:50 PM
