Si axles into ZC tranny
I've searched but with no results, I've got a Civic Si, next to be swapped with a D16A9, the European DOHC ZC, can i use the stock Si axles on the ZC tranny if I remove the intemediate shaft?
or eventually can I use the Si tranny?
thanks, bye!
thanks, bye!
you cannot use the Si axles in the ZC transmission - the ZC axles have a larger end on the inboard CV joint (same as Integra) - you can use the Si transmission with the A9 engine - the Si transmission is geared lower in gears 1-3 than the ZC and will result in quicker acceleration
ok, thank you!
and, if I find the ZC axles, I've read of guys that have replaced the final drive ratio on their ZC tranny with the one of the Si, it's a difficult work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spazius »</TD></TR><TR><TD CLASS="quote">ok, thank you!
and, if I find the ZC axles, I've read of guys that have replaced the final drive ratio on their ZC tranny with the one of the Si, it's a difficult work?</TD></TR></TABLE>
send me Email - jlicrx@yahoo.com
