parts from b18b to b18a??
i was bout to do ls vtec..... i am using the b18a block that i bough for 150 with everything.. piston.. crankshaft.. and was plannng to use the b18b parts like for the water pipe if thats what you call it.. etc.. thanks
the cams, and intake manifold are different between the two engines. They can be swapped, it doesnt really matter that much.
but it sounds like yoiu wont be mixing internal parts from one engine with internal parts from the othjer... you shouldnt have a problem.
