VTEC engagement and disengagement question!?
Old Jun 15, 2007 | 08:38 PM
401tuner's Avatar
Default VTEC engagement and disengagement question!?
i have a 98 GSR and i know VTEC engages at 4400 RPMs and the secondarys open around 5700 RPMs or something close to that, but i was wondering in deceleration at what RPM does VTEC disengage?
Low cam - High cam = 4400
High cam - Low cam = ?
Old Jun 15, 2007 | 08:42 PM
numbnuts22715's Avatar
I would imagine just the reverse.
butterflies close back at 5700, and vtec disenages at 4400.
Old Jun 15, 2007 | 08:53 PM
401tuner's Avatar
Default Re: (numbnuts22715)
i think it disengages lower than it engages but im not sure?
Old Jun 15, 2007 | 09:00 PM
I dunno why it woulddo that...
Why does it even matter?
Old Jun 15, 2007 | 09:13 PM
401tuner's Avatar
because im in the process of tuning my VAFC II and i need to know when VTEC disengages on a GSR
Old Jun 16, 2007 | 08:32 AM
401tuner's Avatar
Default Re: (401tuner)
bump can anyone help?
Old Jun 16, 2007 | 08:46 AM
ziggz501's Avatar
it should be the same, but vtec also disengages if ur less than 50% throttle.
Old Jun 16, 2007 | 09:27 AM
bildo16's Avatar
unless youre over 5500, vtec is engaged no matter what.
Old Jun 16, 2007 | 11:47 AM
401tuner's Avatar
Default Re: (bildo16)
ttt
Old Jun 16, 2007 | 12:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner &raquo;</TD></TR><TR><TD CLASS="quote">i think it disengages lower than it engages but im not sure?</TD></TR></TABLE>
go out and drive your car and see... I really dont understand why it would engage at one rpm and disengage at another rpm....
Chances are its at thesame rpm both ways.
Old Jun 16, 2007 | 01:22 PM
integra686's Avatar
wow vtec engages at wot at 4400. half throttle at 5000. butterflys at 5800. and disengage at 5800. i duno about the vtec disengagment point casue i always drive in vtec but i would set the engage and disengagement at the same point.
Old Jun 16, 2007 | 01:35 PM
Championship's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner &raquo;</TD></TR><TR><TD CLASS="quote">because im in the process of tuning my VAFC II and i need to know when VTEC disengages on a GSR</TD></TR></TABLE>
Old Jun 16, 2007 | 05:43 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bildo16 &raquo;</TD></TR><TR><TD CLASS="quote">unless youre over 5500, vtec is engaged no matter what.</TD></TR></TABLE>
what?
Old Jun 16, 2007 | 05:55 PM
yeah.. he totally worded that backwards, rofl. I didnt catch it til you said soemthing.
which is wrong anyways..once youre at 4400 vtec is engaged no matter what.
but he was responding to the person above who said vtec disengages if you are partial throttling it.
Old Jun 16, 2007 | 08:00 PM
401tuner's Avatar
because they wont let the disengagement point be higher than the engagement point. so yea idk i have the engagement point at 4500 rpms and disengagment at 4000, hopefully thats alright
Old Jun 16, 2007 | 08:20 PM
1.8L_allmotormilitia's Avatar
before i upgraded to skunk2 manifold vtec was 4400 secondary was 5750 and when i was half throttle vtec would hit 4800 rpm.
Old Jun 16, 2007 | 09:59 PM
91DBSexyTime's Avatar
on my VAFC II i have my vtec set at 5700 rpm and dissengage set at 5600 rpm, dont ask me why, my buddy with a type r has his set at that and told me to and it works fine.I actually like having it set at that point because i can actually feel my vtec kicking in, the stock settings i couldnt feel it kicking in but you could notice acceleration, but now i can feeeeeel it crack.thats just my 2 cents.
Old Jun 17, 2007 | 07:54 AM
401tuner's Avatar
Default Re: (91DBSexyTime)
wow i never thought of putting it that high, im sure you can feel it because vtec kicks in and the secondaries open at the same time.
Old Jun 17, 2007 | 10:16 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">
Chances are its at thesame rpm both ways.</TD></TR></TABLE>
VTEC engagement does have a hysteresis. You don't want to keep engaging/disengageing when you hover near the setpoint. This article for the ITR highlights the conditions for the USDM B18C5. I have not seen it for the GSR. These should be in the ECU code.
The last page of the ITR article states VTEC as 5700(engage)/5400(disengage) for WOT and 5900(engage)/5600(disengage) for partial throttle.
Old Jun 17, 2007 | 10:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91DBSexyTime &raquo;</TD></TR><TR><TD CLASS="quote">on my VAFC II i have my vtec set at 5700 rpm and dissengage set at 5600 rpm, dont ask me why, my buddy with a type r has his set at that and told me to and it works fine.I actually like having it set at that point because i can actually feel my vtec kicking in, the stock settings i couldnt feel it kicking in but you could notice acceleration, but now i can feeeeeel it crack.thats just my 2 cents.
does it bog out or fall off of vtec when you shift from 1st to 2nd?
the vtec engagement seems way to high for it to be good, the itr can get away with it being the higher final drive that it has. (well, depends which itr he has )
i would just ditch the vafc and get a hondata and do it the safe way and let some pro who knows what hes doing work on it.
same goes for the OP
the vtec on GSR`s are meant to stay at 4400, where HONDA intended it to stay, unless otherwise you change cams and tranny than you should deff. look in to a hondata or tune on crome.
i just don`t see myself messing around with the ecu and not knowing shiat and asking a whole bunch of noobs here on H-T. :shrugs:
and that is my .02 cents
Old Jun 17, 2007 | 11:18 AM
doood's Avatar
Default Re: (Championship)
feeling it kick in means it's at the wrong point. vtec should be a smooth transition from low to high cam.
Old Jun 17, 2007 | 04:34 PM
Default Re: (doood)
meh whatever, i plan on building another motor anyways, and the vtec doesnt bog at all, everything runs normal on my car and ecu except the ecu is starting to act gay, bought ready to chuck it out the window.
Old Jun 17, 2007 | 05:50 PM
98GSRDC2's Avatar
Default Re: VTEC engagement and disengagement question!? (401tuner)
they should be the same
Old Jun 17, 2007 | 08:36 PM
serr38's Avatar
Default Re: VTEC engagement and disengagement question!? (98GSRDC2)
u answered u own question
Slats
Jan 28, 2008 07:03 AM
ilovemyb16a
Jul 24, 2006 03:14 AM
TenLarge
30
May 30, 2005 08:48 AM
CRXizSLAMM'd
Jul 12, 2004 01:22 PM
Hello-Vtec-Goodbye
Apr 11, 2004 04:41 PM
