Accord Trouble Code..HELP!!
Ok guys I got this 95 honda accord lx and whenever i go to drive it and put it into D4 it starts to flash at me so i jumped the ecu and it blinks 9 times. (not the check engine light, the D4 light) I need to know what the code is and how to go about fixing it. It has the F22b2 and is an auto. Thanks alot guys....THE HONDA DEALER HERE IS NO HELP!
here's a link to the flash codes;
http://img252.imageshack.us/my...j.jpg
When you turn the key on, does the 'D4' light come on for a couple seconds and then go off?
Any other shifting problems or speedo malfunctions?
9 blinks can be due to the following:
- Disconnected countershaft speed sensor connector
- Short or open in the countershaft speed sensor wire
- faulty countershaft speed sensor
Symptom: Lock-up clutch does not engage.
Here is a picture of the countershaft speed sensor connector from Autozone's site:
If it is necessary to replace the countershaft speed sensor, you could follow the connector back to the sensor. Note: The countershaft speed sensor is not the Vehicle speed sensor (VSS).
when my friend and i were doing the swap the countershaft speed sensor connector plug did get destroyed and i went to honda to check out the service manuel for the wiring because the connector has a white wire and a yellow wire and the engine harness has a blue/green and blue yellow wire. i'll post how it is connected later.
Also it doesn't start to flash until i start to drive it and it shifts out of first.
TH3GR33NM4N
Aug 26, 2005 10:11 PM
