MTF change on EP3, How-to?
Old Jun 15, 2007 | 04:46 PM
mormonboy's Avatar
Default MTF change on EP3, How-to?
how do i change the tranny fluid on the EP3?
is the proccedure similar to that of b-series/d-series trannys?
how many quarts of fluid do i need?
thanks alot.
Old Jun 15, 2007 | 05:09 PM
JDMk20R's Avatar
Default Re: MTF change on EP3, How-to? (mormonboy)
it's pretty easy to do, right under the tranny you'll find a 17mm bolt and another one where the standard wratchet head will fit. Here's the thread for it on Clubrsx and should take almost 3Qts of MTF
Take the drivers side wheel off too, makes it a lot easier
http://forums.clubrsx.com/show...hange
Modified by JDMk20R at 6:26 PM 6/15/2007
Old Jun 15, 2007 | 05:31 PM
mormonboy's Avatar
Default Re: MTF change on EP3, How-to? (JDMk20R)
ah, ok cool. same as b-series tranny.
but i thought the EP needs 1.6 quarts?
Old Jun 15, 2007 | 05:34 PM
JDMk20R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mormonboy &raquo;</TD></TR><TR><TD CLASS="quote">ah, ok cool. same as b-series tranny.
not too sure, I thought it was the same as the rsx. Just fill it till it starts flowin out lol, just not too much. I have an rsx and it went about 2.5 quarts
Old Jun 15, 2007 | 06:36 PM
risktypeS's Avatar
you guys realize it's real easy to filling it instead of trying to pour it in the side of where you drained it. Take the Speedo sensor out and start pouring it in. 2 1/2 quartz and your gold. k20a3 trannys should be no different then a k20a2 or k20a (when you're filling them up with MTF)
beevo.
Sep 26, 2005 04:39 PM
litterbox
Feb 14, 2005 12:19 PM
luciffer
Sep 13, 2004 11:24 AM
wizzards581
Mar 8, 2004 09:33 PM
92HB_HB
Oct 21, 2003 12:29 PM
